    • RB Downsize Brake Kit (355/355) for Dodge Ram 1500/TRX 2019+ Fits 17" Wheels (PN 2705-K & 2635)
  • front kit
  • rear kit
  • front Weight
  • rear Weight
  • front kit rear kit front Weight rear Weight
    MSRP: $3,550.00
    Now: $3,335.00
    (You save $215.00 )
    RAM-IRP-355
    Expected release date is Dec 20th 2026
    Installation notes:
    1. Brake kit fits all Dodge Ram 1500/TRX from 2019+ with 6x139.7mm bolt hole pattern with 78.5mm hub registered dia.
    2. Rotors are made to the same offset as the stock rotors.
    3. Brake kit is designed and intended to fit 17" wheels (downsize from stock 18") for off-road applications.
    4. Due to the variety of aftermarket wheels, please download the fitment template to check against your wheels, or inquire your wheel venders before purchase.
    5. We can't be held responsible because of fitment issue.
    Feature & benefit:
    1. The calipers are a 4-pot hevy duty with stainless steel pistons, built to perform and last.
    2. OE rear calipers are retained, mounted to spindle with RB ductile iron brackets, strong and robust suitable for off-rod abuse.
    3. System is designed and manufactured by RB.
    • 2 ea RB460 Heavy Duty 4 pot calipers
    • 1 pair front caliper adaptors
    • 2 ea front 2 pc light weight alloyed iron rotors (355x32 vs. OE 378x30mm)
    • 2 ea rear 2 pc light weight alloyeed iron rotors (355x24 vs. OE 375x22mm)
    • 1 pair rear caliper brackets for downsize rotors
    • 1 car set brake pads (Street/Spirited)
    Feature & Benefit:
    • Fits under 17" wheels for off-road applications.
    • Same rotor size ratio (355/355) like OE (374/374) - Maintain same brake balance.
    • Sustantial weight saving over the stock (see table above).
    • Truly affordable - Cost only fraction of other aftermarket kits.
    • Kit is developed and exclusively made by RB for braking improvement and lasting durability.
    Front brake kit fitment template - Download to check against your 17" aftermarket wheels:
    • 2705-K
    • Front pads: PD1149
    • Rear pads: PD2169
    • Front: 1403-351 (355x32)
    • Rear: D502-07 (355x24)
    Follow this thread on TRX forum for the brake development:
    RB Performance Brakes is a Supporting Vendor of RAM-TRX.com!
    Other Aftermarket brake reference:
    • Rotora kits:
    • Alcon 6-pot Kit
      Wilwood kit (405x34mm)
    • Medias:
    • How to Replace Rear Brakes 2019-2023 Ram 1500
    • Wilwood BBK installation & review
    • Forum discussions:
    • Group Buy
    • Development Story
    • Brakes and Rotor upgrade- not the $5k-$8k ones
    • R1 Big Brake Kits for the TRX!
    • Rotora Brake HD Brake Systems
    • Wilwood TX6R Front Brake Kits for the 2021-2023 Ram TRX
    front kit
    • RB Caliper Kit for RAM TRX (2019+) Front & Rear (PN 2701K & 2702) Fits Stock 18" Wheels RB Caliper Kit for RAM TRX (2019+) Front & Rear (PN 2701K & 2702) Fits Stock 18" Wheels
      MSRP: $4,750.00
      Now: $4,512.00
    • RB 6/4 Pot Caliper Kit w/2 pc Rotors for Dodge Ram 3500 Front & Rear (PN 2706-K & 2707-K) Fits 17” wheels. RB 6/4 Pot Caliper Kit w/2 pc Rotors for Dodge Ram 3500 Front & Rear (PN 2706-K & 2707-K) Fits 17” wheels.
      MSRP: $8,500.00
      Now: $8,075.00
    • brake kit front kit
      RB Front BBK (410x34) for RAM TRX/1500 2019+ & Jeep Wagoneer 22+ Front
      MSRP: $4,725.00
      Now: $4,490.00
    • Save 10% on RB 2 pc Rotor Bundle Kit (355/355) for Dodge Viper 2013+ Repl. (P/N 2343 & 2219) TA pads - 60mm depth
      MSRP: $2,560.00
      Now: $2,430.00
    • RB Brake Kit (355/350) for 2023 Z (RZ34), Infiniti G37/Nissan 370Z Front and Rear (P/N 2133-K & 2134-K) front
      MSRP: $4,633.86
      Now: $4,402.17
