    • ROTOR, PAD, BRAKE KIT
          • F430 SCUDERIA
          • F458/488/599
          • F430
          • LANCER (08-16) EVO 10
          • LANCER (03+06) EVO 8-9
          • 911-SC(65-89) 930/912
      • TECH INFO
        • RX7 Front Two-piece Rotor
        • Z06 Rear Two-piece Rotor
          • 458 CALIFORNIA
          • 458 Speciale
          • F430
          • F430 SCUDERIA
          • F360
          • EMIRA
          • 570S (650S, 675LT, MP4-12C)
          • 720S (750S/600LT)
        • F430 SCUDERIA
        • F458/488/599
        • F430
    • TECH INFO
      • All TECH INFO
          • F430 SCUDERIA
          • F458/488/599
          • F430
      • TECH INFO
    • RB Wheel Studs & Nuts Conversion Kit - M12x1.5 (10 per pack)
          • 458 CALIFORNIA
          • 458 Speciale
          • F430
          • F430 SCUDERIA
          • F360
          • EMIRA
          • 720S (750S/600LT)
    • All ROTOR, PAD, BRAKE KIT
        • F430 SCUDERIA
        • F458/488/599
        • F430
    • TECH INFO
      • All TECH INFO
  • RB Wheel Studs & Nuts Conversion Kit - M12x1.5  (10 per pack) RB Wheel Studs & Nuts Conversion Kit - M12x1.5  (10 per pack) RB Wheel Studs & Nuts Conversion Kit - M12x1.5  (10 per pack) RB Wheel Studs & Nuts Conversion Kit - M12x1.5  (10 per pack) RB Wheel Studs & Nuts Conversion Kit - M12x1.5  (10 per pack) RB Wheel Studs & Nuts Conversion Kit - M12x1.5  (10 per pack)
    MSRP: $136.40
    Now: $129.58
    (You save $6.82 )
    M12x1.5-WS
    Specification:
    • Total length: 80mm
    • Installing length: 67mm
    • Hex head: 8mm
    • Stud aterial: Alloyed steel with block anodized finish.
    • Wheel nut: Chrome plated for lasting finish.
    This wheel stud conversion kit is prefrred by most car enthusiasts who are doing regular matainance on their brakes, wheel/tires.
    Advantage & benefits after cvonversion:
    • No need to remove and reinstall individual stud and nut like OE.
    • The rotors will be held by the wheel studs which can save you a lot of time.
    • Can eliminate the use of retaining screws.
    • RB Wheel Studs+Nuts 80mm for BMW M12x1.5 (10 pc./Axle set)
      MSRP: $124.00
      Now: $117.80
    • kit contents dimensions
      RB Wheel Studs Conversion Kit for Mercedes M14x1.5x50 (10 pc./Axle set)
      MSRP: $124.00
      Now: $117.80
    • image_7512 RB Wheel Studs+Nuts 80mm (Full car set)
      MSRP: $264.00
      Now: $250.80
    • EVO 8/9/10 M12x1.5 Wheel Stud M12x1.5, 14mm longer than stock (10 pc. - Axle Set)
      MSRP: $93.50
      Now: $88.83
    • EVO 8/9/10 M12x1.5 Wheel Stud for Stock Replacement (10 pc. - Axle Set)
      MSRP: $79.20
      Now: $75.24
