Quick view sku: 2112-K Big Brake Kit (4-pot, Slot) - LEGACY (2.5 GT, spec.B) FRONT 05-09 MSRP: $2,522.30 Now: $2,396.19 Add to Cart Compare Quick view sku: 2122 Big Brake Kit (OE Caliper, Slot) - LEGACY REAR (4WD TURBO) 90-94 MSRP: $537.90 Now: $511.01 Add to Cart Compare Quick view sku: 2124-K Big Brake Kit (OE Caliper, Slot) - LEGACY REAR (4WD TURBO) 90-94 AND OTHER SUBARU REAR 316X18mm MSRP: $650.00 Now: $617.50 Choose Options Compare Quick view sku: 2113-K Big Brake Kit (OE Caliper, Slot) - LEGACY REAR (NON 4WD TURBO) 90-06 AND OTHER SUBARU REAR 290X18mm MSRP: $599.50 Now: $569.53 Add to Cart Compare Quick view sku: 2123-K Big Brake Kit (OE Caliper, Slot) - LEGACY REAR (NON 4WD TURBO) 90-06 AND OTHER SUBARU REAR 318X18mm MSRP: $789.80 Now: $750.31 Add to Cart Compare Quick view sku: CB09D Caliper Brackets - For Subaru Rear BBK Upgrade to Legacy 2.5GT w/316x18 mm Rotors - Price per pair (x2) MSRP: $305.00 Now: $289.75 Add to Cart Compare Quick view sku: 2112 RB 2 pc Rotor - LEGACY (2.5 GT, spec.B) FRONT 05-09 MSRP: $1,024.10 Now: $972.90 Add to Cart Compare Quick view sku: 2020 RB 2 pc Rotor for LEGACY 2.5 GT FRONT 05-09 MSRP: $833.80 Now: $720.99 Choose Options Compare Quick view sku: 2014-K RB BBK (322x25) for Subaru BRZ, Scion FR-S, GT86 Front MSRP: $2,265.00 Now: $2,150.00 Compare Quick view sku: 2060-K RB Rear rotor OE Caliper BBK (316X18mm) - LEGACY GT REAR 05-08 AND OTHER SUBARU REAR MSRP: $490.00 Now: $465.55 Choose Options Compare SALE Quick view sku: BRZ-IRP-02 Save 10% on RB BBK/OE Caliper kit (322/316) for Subaru BRZ, Scion FR-S, GT86 (2014-K & 2060-K) MSRP: $2,579.00 Was: $2,450.05 Now: $2,321.10 Choose Options Compare Quick view Big Brake Kit (4-pot, Slot) - LEGACY (2.5 GT, spec.B) FRONT 05-09 This kit includes: 2 Two-piece center-mount rotors 2 RB 4-Piston calipers MSRP: $2,522.30 Now: $2,396.19 Add to Cart Compare Quick view Big Brake Kit (OE Caliper, Slot) - LEGACY REAR (4WD TURBO) 90-94 This Kit Includes: 2 ea. Alloyed one-piece rotors (9152-111) 2 ea. Extended high strength brackets MSRP: $537.90 Now: $511.01 Add to Cart Compare Quick view Big Brake Kit (OE Caliper, Slot) - LEGACY REAR (4WD TURBO) 90-94 AND OTHER SUBARU REAR 316X18mm Kit Contents Option: 2 ea Rotors (318x16mm) Alloyed and ventilated. 2 ea Upgrade BBK brackets (Optional) - For non Turbo owners. 1 set Brake pads (Optional) MSRP: $650.00 Now: $617.50 Choose Options Compare Quick view Big Brake Kit (OE Caliper, Slot) - LEGACY REAR (NON 4WD TURBO) 90-06 AND OTHER SUBARU REAR 290X18mm This kit is a +1 kit for vehicles with 290x18mm rotors. This kit fits the following vehicles:LEGACY REAR (NON 4WD TURBO) 90-06FORESTER REAR 98-09OUTBACK REAR 95-09 The rotors in this brake kit are 18mm thic MSRP: $599.50 Now: $569.53 Add to Cart Compare Quick view Big Brake Kit (OE Caliper, Slot) - LEGACY REAR (NON 4WD TURBO) 90-06 AND OTHER SUBARU REAR 318X18mm This kit is a +2 kit for vehicles with 266x10mm stock rotors and a +1 kit for vehicles with 290x10mm rotors. This kit fits the following vehicles:LEGACY REAR (NON 4WD TURBO) 90-06FORESTER REAR 98-09OUTBACK REAR 95-09 MSRP: $789.80 Now: $750.31 Add to Cart Compare Quick view Caliper Brackets - For Subaru Rear BBK Upgrade to Legacy 2.5GT w/316x18 mm Rotors - Price per pair (x2) This bracket allows you to upgrade your Subaru rear rotors to Legacy 2.5GT 316x18 mm rotors. Replacement Rotors for this brake kit: P/N: 9160-01 MSRP: $305.00 Now: $289.75 Add to Cart Compare Quick view RB 2 pc Rotor - LEGACY (2.5 GT, spec.B) FRONT 05-09 Replacement rotor ring: D215-04 MSRP: $1,024.10 Now: $972.90 Add to Cart Compare Quick view RB 2 pc Rotor for LEGACY 2.5 GT FRONT 05-09 Kit contains: 2 ea two piece rotors Disc finish available (Select at option): Surface Slots - 311 Drill & Slots - 351 MSRP: $833.80 Now: $720.99 Choose Options Compare Quick view RB BBK (322x25) for Subaru BRZ, Scion FR-S, GT86 Front This Brake Kit Is Obsolete & Superseded by P/N 2567-K (332x28mm)! If you purchased this BBK (322x25mm) in early 2000 and are looking for replacement rotor rings, be advised they are no longer available, instead you should puchase a new rotor assembly... MSRP: $2,265.00 Now: $2,150.00 Compare Quick view RB Rear rotor OE Caliper BBK (316X18mm) - LEGACY GT REAR 05-08 AND OTHER SUBARU REAR This kit is a +1 kit for vehicles with 290x18mm stock rotors. This Kit Includes: 2 ea. Alloyed one-piece rotors (9160-01-111 or 9160-01-141) 2 ea. Extended high strength brackets (CB09D) MSRP: $490.00 Now: $465.55 Choose Options Compare SALE Quick view Save 10% on RB BBK/OE Caliper kit (322/316) for Subaru BRZ, Scion FR-S, GT86 (2014-K & 2060-K) Replacement components Brake pads: Front: PD647 Rear: PD770 Front rotor rings: D214-01 Rear 1pc: 9160-141 MSRP: $2,579.00 Was: $2,450.05 Now: $2,321.10 Choose Options Compare Compare Selected × OK
