Quick view RB 2Pc Rotor kit (380x32/370x26) for M3/M4 F80 Stock Replacement (P/N 2384 & 2385) MSRP: $2,650.00 Was: Now: $2,495.00 Choose Options Compare Quick view RB 2Pc Rotor kit (400x38/380x28) for M3/M4 F80 with Gold Calipers: CCB to Iron Conversion (P/N 2490 & 2524) MSRP: $3,430.00 Was: Now: $3,090.00 Choose Options Compare Quick view RB-CCB Rotor Kit (380/380) for BMW M2/M3/M4 F80 Conversion Upgrade from Iron Rotors (PN 2C94 & 2C80) MSRP: $12,150.00 Was: Now: $11,530.00 Pre-Order Now Compare Quick view RB-CCB Rotor Kit (400/380) for BMW M3/M4 F80 CCB Rotor Replacement (PN 2R13 & 2C14) MSRP: $13,600.00 Was: Now: $12,920.00 Choose Options Compare Quick view RB-CCB System Kit (380/380) for BMW M2, M3, M4 F80 (15-20); M3 E90 (08-13) (P/N 2C94 & 2C80) MSRP: $16,200.00 Was: Now: $15,390.00 Choose Options Compare Quick view RB-CCB System Kit (394/380) for BMW M2/3/4 F80 (14-20) ; M3 E90 (07-13) (P/N 2C82 & 2C14) MSRP: $17,850.00 Was: Now: $16,960.00 Choose Options Compare Quick view RB 2Pc Rotor kit (380x32/370x26) for M3/M4 F80 Stock Replacement (P/N 2384 & 2385) Kit contains: 2 ea. front RB 2 pc rotors (380x32 vs. OE 380x30) 2 ea. rear RB 2 pc rotors (370x26 vs. OE 370x24) Brake pads are not available. Note: Our rotors are made 2mm thicker than OE (both front and rear) for extra thermal capacities, and are... MSRP: $2,650.00 Was: Now: $2,495.00 Choose Options Compare Quick view RB 2Pc Rotor kit (400x38/380x28) for M3/M4 F80 with Gold Calipers: CCB to Iron Conversion (P/N 2490 & 2524) *This 2pc rotor kit is designed for BMW M3/M4 with 6/4 pot Gold calipers. (not included) Kit contains: 2 ea. front RB two-piece rotors 2 ea. rear RB two-piece rotors 1 Car set of street performance brake pads. Brake pads included in this kit are for... MSRP: $3,430.00 Was: Now: $3,090.00 Choose Options Compare Quick view RB-CCB Rotor Kit (380/380) for BMW M2/M3/M4 F80 Conversion Upgrade from Iron Rotors (PN 2C94 & 2C80) This kit is specially designed for F80 owners with standard iron brake for conversion upgrade to ccb rotors with 6/4 pot gold calipers; but the front rotors are downsized to 380mm (from 400mm) allowing you to run smaller wheels (19" recommended)... MSRP: $12,150.00 Was: Now: $11,530.00 Pre-Order Now Compare Quick view RB-CCB Rotor Kit (400/380) for BMW M3/M4 F80 CCB Rotor Replacement (PN 2R13 & 2C14) Kit includes: 2 ea front 400x38mm CCB rotors 2 ea rear 380x30mm CCB rotors (vs. OE 380x28) 1 car set of CCB brake pads (optional) Features and benefits: Bolt on installation, no modifications is required. Stay in OE configuration, re-use OE... MSRP: $13,600.00 Was: Now: $12,920.00 Choose Options Compare Quick view RB-CCB System Kit (380/380) for BMW M2, M3, M4 F80 (15-20); M3 E90 (08-13) (P/N 2C94 & 2C80) Kit includes: 2 RB6M 6-piston calipers 2 RB4M 4-piston rear calipers 2 Front CCM Rotor (380x34mm) 2 Rear CCM Rotor (380x30mm) 4 Aluminum caliper adaptors 1 car set CCB brake pads 1 car set brake lines Installtion requires 18-19" wheels Weight... MSRP: $16,200.00 Was: Now: $15,390.00 Choose Options Compare Quick view RB-CCB System Kit (394/380) for BMW M2/3/4 F80 (14-20) ; M3 E90 (07-13) (P/N 2C82 & 2C14) Kit includes: 2 RB6L 6-piston calipers 2 RB4L 4-piston rear calipers 2 Front CCM Rotor (394x36mm) 2 Rear CCM Rotor (380x30mm) 4 Aluminum caliper adaptors 1 car set CCB brake pads 1 car set brake lines Inatallation requires 19-20" wheels Weight... MSRP: $17,850.00 Was: Now: $16,960.00 Choose Options Compare Compare Selected × OK
