    • RB BBK (400/390) for Corvette C8 Front & Rear (P/N 2659-K & 2646-K)
  • Car kit
  • Front rotor wt
  • Front rotor
  • Front BBK
  • Rear rotor wt
  • Rear rotor
  • Rear BBK
  • Front 6 pot caliper
  • Front brake pad
  • Rear 4 pot caliper
  • Rear brake pad
  • Car kit Front rotor wt Front rotor Front BBK Rear rotor wt Rear rotor Rear BBK Front 6 pot caliper Front brake pad Rear 4 pot caliper Rear brake pad
    MSRP: $9,328.00
    Now: $8,861.60
    (You save $466.40 )
    C8-IRP-02
    Front Kit:
    • Caliper: RB6LB 6 pot track duty calipers (w/stainless steel pistons and internal dust seals)
    • Rotor: 400x34mm (Featured RB center-mount design for an efficient cooling)
    • Pads: Same as Corvette ZR1 (Must trim the excessive bottom from OE 87mm to effctive depth 78mm)
    Rear Kit:
    • Caliper: RB4L2 4 pot track duty calipers (w/stainless steel pistons and internal dust seals)
    • Rotor: 390x28mm (Featured RB center-mount design for an efficient cooling)
    • Pad: Same as Corvette ZR1 (Fully compatible with OE parking brake, required spacers are included)
    Brake pads included in the kit are for street+ driving, for off-street applications please contact us for assistance.
    Front: PD1395
    Rear: PD1165
    Front: D601-03
    Rear: D603-06
    Front: 2659-K
    Rear: 2646-K
    Brake line installation note:
    1. We make the femal fitting (to the rigid line) swivel (unlike OE which is fixed) but not the banjo, so you should install the banjo to the caliper first; then secure the femal fitting to the rigid line to complete the installation.
    2. The brackets were transferred from OE and because the custom stainless braided lines are smaller in diameter so they are loose, but can be secured to the line by wrapping the duct tape (included) onto the line then slide the brackets to make a tighter fit. You will find this is easier to install than OE which all the brackets are fixed (non moveable) to the line.
    Car kit
    • RB BBK (420/390) for Corvette C8 Front & Rear (P/N 2670-K & 2646-K) RB BBK (420/390) for Corvette C8 Front & Rear (P/N 2670-K & 2646-K)
      MSRP: $10,512.00
      Now: $9,986.60
    • RB BBK (380/390) for Corvette C8 Z51 & non-Z51/base model (Stingray) Front & Rear (P/N 2302-K & 2646-K) RB BBK (380/390) for Corvette C8 Z51 & non-Z51/base model (Stingray) Front & Rear (P/N 2302-K & 2646-K)
      MSRP: $8,600.00
      Now: $8,170.00
    • Pic is for general reference only - Refer to description for the components in the kit RB-CCB System BBK (400/390) for Corvette C8 (P/N 2R15-K & 2R19-K)
      MSRP: $16,300.00
      Now: $15,490.00
    • Pic is for general reference only - Refer to description for the components in the kit RB-CCB System BBK (420/390) for Corvette C8 (P/N 2R18-K & 2R19-K)
      MSRP: $18,350.00
      Now: $16,520.00
    • RB-CCB System BBK (380/390) for Corvette C8 Conversion Upgrade from Stock Iron Rotors Front & Rear (P/N 2R14-K & 2R19-K) - Fits OE 19" Wheels Front kit
      MSRP: $15,780.00
      Now: $14,990.00
