Quick view [PD594-391] RB XT910 Brake Pad for Porsche 993 Turbo Front MSRP: $190.00 Was: Now: $180.50 Compare Quick view [PD608-391] RB XT910 Brake Pad: Porsche 993 Rear MSRP: $110.00 Was: Now: $104.50 Add to Cart Compare Quick view [PD609-33] RB ET300 Brake Pad: Porsche 993 Front, Stoptech (ST-40) 4-piston caliper MSRP: $140.00 Was: Now: $133.00 Add to Cart Compare Quick view RB 2 pc Rotor Kit (300X24) for Porsche Boxster, 993 Base (CS) Rear - See Installation Note Under Description for the Required Modification before Ordering. MSRP: $1,350.00 Was: Now: $1,285.50 Pre-Order Now Compare Quick view RB 2 pc Rotor Kit (304x32) for Porsche 993 CS Front MSRP: $1,200.00 Was: Now: $1,140.00 Choose Options Compare Quick view RB 2 pc Rotor Kit (322x28) for Porsche 993 TT & RS Rear MSRP: $1,400.00 Was: Now: $1,330.00 Choose Options Compare Quick view RB 2pc Rotor Kit (322x32) for Porsche 993 Turbo & RS Front MSRP: $1,300.00 Was: Now: $1,235.00 Choose Options Compare Quick view RB 2pc Rotor Kit BBK (330x32) for Porsche 993 All Models MSRP: $1,450.00 Was: Now: $1,380.00 Choose Options Compare Quick view [PD594-391] RB XT910 Brake Pad for Porsche 993 Turbo Front FRONT for PORSCHE: 93-98 911 Turbo, 95-97 911 Carrera RS & RSR, 1995 911 GT2, 92-95 928 GTS 32V, 93-95 968 Coupe Turbo S FRONT &/or REAR for PORSCHE: 87-91 959 2.8L D594, AP594, PFC 0594, Pagid 1842, HB184.650, FCP891 MSRP: $190.00 Was: Now: $180.50 Compare Quick view [PD608-391] RB XT910 Brake Pad: Porsche 993 Rear FRONT &/OR REAR for FERRARI: 93-94 348 GTB/GTS/Spider, 90-92 348 TB, 89-92 348 TS, 94-99 F355 // PORSCHE: 82-88 911, 82-89 911 Turbo, 89-98 911 C4, 1991 911 C2 w/Turbo Look, 91-94 911 C4 w/Turbo Look Pkg, 93-94 911 C2 RS America Type... MSRP: $110.00 Was: Now: $104.50 Add to Cart Compare Quick view [PD609-33] RB ET300 Brake Pad: Porsche 993 Front, Stoptech (ST-40) 4-piston caliper FRONT for PORSCHE: 93-94 911 C2 RS w/Turbo Look, 94-98 911 C2 RS Type 993, 95-97 911 Carrera, 90-91 944 Koni Sport Susp, 89-91 944 Turbo, 92-95 968 Sport REAR for PORSCHE: 95-98 911 Turbo Also fits STOPTECH ST-40 Caliper D609, D447, D372,... MSRP: $140.00 Was: Now: $133.00 Add to Cart Compare Quick view RB 2 pc Rotor Kit (300X24) for Porsche Boxster, 993 Base (CS) Rear - See Installation Note Under Description for the Required Modification before Ordering. Installation notes: This rotor although is made for a direct replacement to stock, but in order to accommodate the OE parking brake drum with 180mm dia, the brake pads bottom needs to trim to about 40mm depth to avoid overhang. Kit includes: 2 ea 2 pc... MSRP: $1,350.00 Was: Now: $1,285.50 Pre-Order Now Compare Quick view RB 2 pc Rotor Kit (304x32) for Porsche 993 CS Front Kit Includes: 2 ea 2 pc rotors - 304x32mm 1 set brake pads - Optional Features: 2 pc construction. Direct stock replacement. Light weight (14.7 lbs) Track duty. Replacement components: Discs: D300-08-381 Pads: PD609/Pagid 1204 MSRP: $1,200.00 Was: Now: $1,140.00 Choose Options Compare Quick view RB 2 pc Rotor Kit (322x28) for Porsche 993 TT & RS Rear Kit Includes: 2 ea 2 pc rotors - 322x28mm 1 set brake pads - Optional Features: True 2 pc construction. Direct stock replacement with 100% bolt on installation. Retain OE rear parking/emergency brake. Light weight: 14.5 vs. OE 18.3, save 3.8... MSRP: $1,400.00 Was: Now: $1,330.00 Choose Options Compare Quick view RB 2pc Rotor Kit (322x32) for Porsche 993 Turbo & RS Front Kit Includes: 2 ea 2 pc rotors - 322x32mm 1 set brake pads - Optional Features: 2 pc construction. Direct stock replacement. Light weight (17.5 lbs) Track duty. Replacement components: Discs: D300-09 Pads: PD594/Pagid 1842 MSRP: $1,300.00 Was: Now: $1,235.00 Choose Options Compare Quick view RB 2pc Rotor Kit BBK (330x32) for Porsche 993 All Models Kit includes: 2 ea 2 pc rotors (330x32mm vs. OE 322x32mm) 1 set Caliper spacer kit w/hardware 1 set brake pads (optional) Features: Direct bolt-on installation w/o any modifications. Instant BBK upgrade while retaining stock (Big Red) calipers. Light... MSRP: $1,450.00 Was: Now: $1,380.00 Choose Options Compare Compare Selected × OK
