Quick view RB 2pc Rotor Kit (355x32) Stock Replacement for Tundra 07-21 Front MSRP: $1,536.00 Was: Now: $1,460.00 Compare Quick view RB 6/4 Pot Caliper BBK (410/400) for Tundra (07-21) Front & Rear w/Drum Brake (P/N 2264-K & 2711-K) - Fits 20" Wheels MSRP: $8,415.00 Was: Now: $7,995.00 Choose Options Compare Quick view RB Brake Kit (355x32) for Tundra 07-21 Front Fits 18" Wheels MSRP: $3,150.00 Was: Now: $2,995.00 Choose Options Compare Quick view RB 2pc Rotor Kit (355x32) Stock Replacement for Tundra 07-21 Front These two-piece rotors were engineered to be the best stock replacement two-piece rotor on the performance market. This rotor is direct bolt-on, easy to install, no additional hardware needed. They can deliver consistent brake torque under extreme heat. MSRP: $1,536.00 Was: Now: $1,460.00 Compare Quick view RB 6/4 Pot Caliper BBK (410/400) for Tundra (07-21) Front & Rear w/Drum Brake (P/N 2264-K & 2711-K) - Fits 20" Wheels Kit includes: 2 ea 2 pc rotors (410x34mm) 2 ea RB6M3 6pot HD calipers 2 ea front caliper adaptors 2 ea 2 pc rotors (400x30mm) 2 ea RB4M 4pot HD calipers 2 ea rear caliper adaptors 1 car set brake pads 1 car set brake lines Replacement pads: Front... MSRP: $8,415.00 Was: Now: $7,995.00 Choose Options Compare Quick view RB Brake Kit (355x32) for Tundra 07-21 Front Fits 18" Wheels Installation note: Download wheel fitment diagram to check the wheel clearance before ordering. Installation requires 18"+ wheels For OE wheels installation, adding 1/2" wheel spaces are required to clear the wheel spokes. Rotor wt: 21 lbs vs. OE 28... MSRP: $3,150.00 Was: Now: $2,995.00 Choose Options Compare Compare Selected × OK
