Quick view RB-CCB Disc (345X32mm) - Price per pair. MSRP: $4,750.00 Was: Now: $4,515.00 Add to Cart Compare Quick view RB-CCB Disc (350x28mm) - Price per pair. MSRP: $4,750.00 Was: Now: $4,515.00 Add to Cart Compare Quick view RB-CCB Disc (380x34x67mm) - Price per pair. MSRP: $4,500.00 Was: Now: $4,275.00 Add to Cart Compare Quick view RB-CCB Disc (380x34x82mm) - Price per pair. MSRP: $4,750.00 Was: Now: $4,515.00 Add to Cart Compare Quick view RB-CCB Disc (390x28mm) - Price per pair. MSRP: $4,620.00 Was: Now: $4,389.00 Choose Options Compare Quick view RB-CCB Disc (390x36mm) - Discs are made directional (Price per Pair) MSRP: $5,400.00 Was: Now: $5,130.00 Choose Options Compare Quick view RB-CCB Disc (400x28mm) - Price per pair MSRP: $4,800.00 Was: Now: $4,560.00 Choose Options Compare Quick view RB-CCB Disc (400x36mm) - Price per pair. MSRP: $5,455.00 Was: Now: $5,180.00 Choose Options Compare Quick view RB-CCB Disc (410X30mm) - Price per pair. MSRP: $5,000.00 Was: Now: $4,750.00 Choose Options Compare Quick view RB-CCB Disc (345X32mm) - Price per pair. Discs are designed and made with long (continuous) carbon fibers which is stronger and more durable than Brembo's chopped fibers. Dimensions are fully compatible with OE CCM rotor components. Note: Required rotor hat and hardware are not included; you... MSRP: $4,750.00 Was: Now: $4,515.00 Add to Cart Compare Quick view RB-CCB Disc (350x28mm) - Price per pair. Discs are designed and made with long (continuous) carbon fibers which is stronger and more durable than Brembo's chopped fibers. Dimensions are fully compatible with OE CCM rotor components. Note: Required rotor hat and hardware are not included; you... MSRP: $4,750.00 Was: Now: $4,515.00 Add to Cart Compare Quick view RB-CCB Disc (380x34x67mm) - Price per pair. Discs are made with long carbon fibers for a direct replacement to OE/Brembo ccb front rotors for Corvette ZR1 C6, C7 etc. See tech info. Advantage: Reuse OE hats and hardware 100% interchangeable with OE/Brembo discs Discs are made of continuous carbon... MSRP: $4,500.00 Was: Now: $4,275.00 Add to Cart Compare Quick view RB-CCB Disc (380x34x82mm) - Price per pair. Discs are designed and made with long (continuous) carbon fibers which is stronger and more durable than Brembo's chopped fibers. Dimensions are fully compatible with OE CCM rotor components. Note: Required rotor hat and hardware are not included; you... MSRP: $4,750.00 Was: Now: $4,515.00 Add to Cart Compare Quick view RB-CCB Disc (390x28mm) - Price per pair. MSRP: $4,620.00 Was: Now: $4,389.00 Choose Options Compare Quick view RB-CCB Disc (390x36mm) - Discs are made directional (Price per Pair) This rotor ring is a replacement disc. Note: Necessary hardware kits are not included but can be purchased separately. MSRP: $5,400.00 Was: Now: $5,130.00 Choose Options Compare Quick view RB-CCB Disc (400x28mm) - Price per pair MSRP: $4,800.00 Was: Now: $4,560.00 Choose Options Compare Quick view RB-CCB Disc (400x36mm) - Price per pair. This rotor ring is a replacement disc. Note: Necessary hardware kits are not included but can be purchased separately. MSRP: $5,455.00 Was: Now: $5,180.00 Choose Options Compare Quick view RB-CCB Disc (410X30mm) - Price per pair. This rotor ring is a replacement disc. Note: Necessary hardware kits are not included but can be purchased separately. MSRP: $5,000.00 Was: Now: $4,750.00 Choose Options Compare 1 2 Next 1 2 Next Compare Selected × OK
