      • All ACCESSORIES
    • RB-CCB System BBK (400/390) for Corvette C8 (P/N 2R15-K & 2R19-K)
      • All ACCESSORIES
  • Pic is for general reference only - Refer to description for the components in the kit
  • Pic is for general reference only - Refer to description for the components in the kit RB-CCB System BBK (400/390) for Corvette C8 (P/N 2R15-K & 2R19-K) RB-CCB System BBK (400/390) for Corvette C8 (P/N 2R15-K & 2R19-K) RB-CCB System BBK (400/390) for Corvette C8 (P/N 2R15-K & 2R19-K) RB-CCB System BBK (400/390) for Corvette C8 (P/N 2R15-K & 2R19-K) RB-CCB System BBK (400/390) for Corvette C8 (P/N 2R15-K & 2R19-K) RB-CCB System BBK (400/390) for Corvette C8 (P/N 2R15-K & 2R19-K)
    MSRP: $16,300.00
    Now: $15,490.00
    (You save $810.00 )
    RCCB-C8-400.390
    • Bolt on installation w/o requiring any modification.
    • Wheel requirement: 20" or larger.
    • Retain rear OE parking brake (spacers included).
    • Rotors are made of continuous carbon fiber, and are directional for efficient cooling. (learn more)
    • RB calipers are built for ultimate tracking performance and durability.
    • Caliper default color is Red, other optional finishes are available w/price adder.
    Kit contains:
    • 2 ea. RB 6-piston calipers & adaptors
    • 2 ea. RB 4-piston calipers & adaptors
    • 2 ea. Front CCM rotor (400x36mm)
    • 2 ea. Rear CCM rotor (390x28mm)
    • 2 ea. Parking brake caliper spacers & hardware
    • 1 car set brake pads specially made for CCM rotor
    • 1 car set brake lines
    Brake pad replacement:
    • Front: PD1395
    • Rear: PD1165
    • Front: 2R15-K
    • Rear: 2R19-K
    Leadtime:
    Please understand although we have standarized the design and production on these kits, and most components are in stock, but due to the complexity of components & subcomponents, it generally requires about 2 weeks for assembly, testing, and final insepction before a shipment can be made.
    If a customer prefers certain caliper finish (color) than defult RED the order leadtime is subejct to extension due to caliper availability.
    A ship date will be advised upon order receipt and our review of components availability and production schedule, but once promised your order will be shipped as scheduled.
    Brake line installation note:
    1. We make the femal fitting (to the rigid line) swivel (unlike OE which is fixed) but not the banjo, so you should install the banjo to the caliper first; then secure the femal fitting to the rigid line to complete the installation.
    2. The brackets were transferred from OE and because the custom stainless braided lines are smaller in diameter so they are loose, but can be secured to the line by wrapping the duct tape (included) onto the line then slide the brackets to make a tighter fit. You will find this is easier to install than OE which all the brackets are fixed (non moveable) to the line.
    • Pic is for general reference only - Refer to description for the components in the kit RB-CCB System BBK (420/390) for Corvette C8 (P/N 2R18-K & 2R19-K)
      MSRP: $18,350.00
      Now: $16,520.00
    • RB-CCB System BBK (380/390) for Corvette C8 Conversion Upgrade from Stock Iron Rotors Front & Rear (P/N 2R14-K & 2R19-K) - Fits OE 19" Wheels Front kit
      MSRP: $15,780.00
      Now: $14,990.00
    • Car kit Front rotor wt
      MSRP: $9,328.00
      Now: $8,861.60
    • RB BBK (420/390) for Corvette C8 Front & Rear (P/N 2670-K & 2646-K) RB BBK (420/390) for Corvette C8 Front & Rear (P/N 2670-K & 2646-K)
      MSRP: $10,512.00
      Now: $9,986.60
      MSRP: $16,737.88
      Now: $15,900.99
