    • RB-CCB (410/390) Rotor Kit for Porsche 991 GT3, 718 GT4 pccb Stock Replacement (P/N: 2C19 & 2C20)
  • CAR SET
  • 2C19 FRONT CENTER LOCK
  • 2C20 REAR CENTER LOCK
  • 2C34 FRONT 5 LUG -
  • 2C55 REAR 5 LUG - 380mm
  • 2C26 FRONT CENTER LOCK - 380mm
  • CAR SET 2C19 FRONT CENTER LOCK 2C20 REAR CENTER LOCK 2C34 FRONT 5 LUG - 2C55 REAR 5 LUG - 380mm 2C26 FRONT CENTER LOCK - 380mm
    MSRP: $14,210.00
    Now: $13,500.00
    (You save $710.00 )
    POR-crk-410.390-repl
    • 2 ea Front CCM rotors
    • 2 ea Rear CCM rotors
    • 1 car set of CCB pads (optional)
    • 1 set Caliper mounting hardware (for upgrade kit only)
    Upgrade kit includes all necessary hardware (spacers, bolts etc.) to space the Red calipers to CCB size rotor (410/390mm) from iron rotors (380/380mm)
    Features and benefits:
    This CCM rotor kit is specially developed for 981 GT4 upgrading from Red calipers w/iron rotors direct replacement to the latest CCM brake technology.
    • RB CCM rotors are stronger and can run cooler than OE pccb.
    • CCM rotors (Brembo, ST or RB) have "Diamond hard" surface with excellent "Thermal Stability" so they will NEVER Wear*, Warp, or Crack (due to the heat). More advantageous for tracking/racing.
    • Rotor annulus are wide enough to fit Pccb pads (74mm vs. iron's 62mm in depth) for lower braking temperature.
    • Literally no brake dust.
    • Reduce unsprung weight.
    • Improve driving comfort.
    • Front: PD1768
    • Rear: PD1740
    Weights:
    OE Hub Spec. Front Rear
    PCCB C/L 15.85lbs (2C19) 14.10lbs (2C20)
    PCCB 5/L (2C43) (2C55)
    Iron C/L (2C26) (2C20)
    Iron 5/L (2C34) (2C55)
    CAR SET
    • RB-CCB System Kit (410/390) for Porsche 991/992/GT4 (2C19-K & 2C20-K) Front 6 Pot
      MSRP: $18,850.00
      Now: $17,900.00
    • RB-CCB Rotor Conversion Upgrade (410/390) for Porsche 991/GT4 (2C26 & 2C20)
      MSRP: $14,580.00
      Now: $13,850.00
    • CAR SET
      RB-CCB (410/380) Rotor Kit for Porsche 992 GT3, 718 (981-982) GT4 RS PCCB Stock Replacement or Iron Upgrade.
      MSRP: $13,650.00
      Now: $12,960.00
    • RB-CCB (420/390) Rotor Kit for Porsche 992 Turbo S Pccb Replacement  (PN 2R41 & 2C20) RB-CCB (420/390) Rotor Kit for Porsche 992 Turbo S Pccb Replacement  (PN 2R41 & 2C20)
      MSRP: $14,370.00
      Now: $13,650.00
    • RB 2 Pc Rotor Kit (410/390) for Porsche 991 GT3 (CCB to Iron Conversion)
      MSRP: $4,200.00
      Now: $3,990.00
