    • RB BBK (400/380) for Ford Explorer ST (2020+) Upgrade Front & Rear (P/N 2669-K & 2726-K)
  • Front kit
  • Rear kit
  • Front assembly
  • Rear assembly
  • Front kit Rear kit Front assembly Rear assembly
    MSRP: $8,410.00
    Now: $7,990.00
    (You save $420.00 )
    FOR-IRK-400.380
    Kit contents (Turn-key package):
    • 2 ea Front RB 6 pot calipers
    • 2 ea Front 2 pc rotors (400x34 vs. OE 360x32)
    • 2 ea Front caliper adaptors
    • 2 ea Rear RB 4 pot calipers w/integrated ePB
    • 2 ea Rear 2 pc rotors (380x28 vs. OE 350x26)
    • 2 ea Rear caliper adaptors
    • 1 car set brake pads
    • 1 car set SS braided brake lines
    • Everything you need in one package, nothing else to add or purcahse.
    • Bolt-on installation (No modifications)
    • Requires 20" (min) wheels to install.
    • Front: PD1395-391
    • Rear: PDS4E1-391
    • Front: D601-03
    • Rear: D502-03
    • Front: 2669-K
    • Rear:  2726-K
    Feature & benefits on RB rear caliper:
    • Easy installation - Simply swap e-motor from OE to RB caliper.
    • Functionality and intergtity of OE calipers are fully retained.
    • Improve the braking performance.
    • Maintain even brake pad wear due to the fixed pistons for instant & even response from both sides vs. OE signle piston with a "push then pull" action.
    • Use only one set of brake pad vs. 2 sets on those with a separate parking brake.
    • Easy and low maintenance vs. OE 1 caliper or 2nd parking calipers set up.
    GT500 rear brake w/a separate parking brake:
    Front kit
    • RB BBK (380/380) for Porsche 996 & 997 Upgrade (P/N 2338-K & 2433-K) RB BBK (380/380) for Porsche 996 & 997 Upgrade (P/N 2338-K & 2433-K)
      MSRP: $9,400.00
      Now: $8,930.00
    • image_8388 RB BBK (380/350) for  Ford Focus ST/RS 2011+ (P/N 2564-K & 2565-K)
      MSRP: $4,440.00
      Now: $4,220.00
    • RB BBK (380/365) for Tesla Model 3 Front+Rear (P/N 2605-K & 2633-K) Rear
      MSRP: $6,260.00
      Now: $5,950.00
    • Car kit Front rotor wt
      MSRP: $9,328.00
      Now: $8,861.60
    • RB BBK (380/380mm) Front & Rear for 2023 Z (RZ34), G37/370Z (P/N 2593-K & 2594-K) RB BBK (380/380mm) Front & Rear for 2023 Z (RZ34), G37/370Z (P/N 2593-K & 2594-K)
      MSRP: $7,500.00
      Now: $7,125.00
