    • RB 4-Piston Rear Caliper Kit w/Actuator for Direct Replacement & Upgrade for Mercedes 1-pot Rear Calipers w/ePB. Priced and Sold in Pair (Rotors are NOT included.)
  • for iron rotor setup
  • for ccb rotor setup
  • caliper weight
  • Mercedes rear 1 pot caliper w/ePB
  • behind the wheel
  • replaced with rb 5-pot caliper
  • behind the wheel
  • park in grade
  • park in grade
  • for iron rotor setup for ccb rotor setup caliper weight Mercedes rear 1 pot caliper w/ePB behind the wheel replaced with rb 5-pot caliper behind the wheel park in grade park in grade
    MSRP: $2,500.00
    Now: $2,375.00
    (You save $125.00 )
    ePB-MB
    • 2 ea RB4e1 4-Pot rear calipers
    • 2 ea Caliper adaptors for stock resr rotors (360x26mm)
    • 1 axle set Street pads (iron or ccb) - select at option
    Feature & benefits:
    • Caliper has a 4 pistons for regular braking plus 1 piston for parking.
    • Provides more efficient braking performance (total 5 pistons) than OE 1 pot floating caliper.
    • Calipers & adaptors are specifically designed & made to fit your model/year stock rotors.
    • Direct swp, easy installation and maintainance.
    • Improve performance.
    • More visual appeal behind the wheels than OE 1-pot floating calipers.
    • For iron rotors: PDS4E1-391
    • For CCB rotors: PDS4E1-360
      RB 4-Piston Rear Caliper Kit w/Actuator for Direct Replacement & Upgrade for BMW OE 1-pot Rear Calipers w/ePB. Priced and Sold in Pair (Rotors are NOT included.)
      MSRP: $2,500.00
      Now: $2,375.00
    • for iron rotor setup 400mm rear bbk
      RB 4-Piston Rear Caliper Kit w/Actuator for Direct Replacement / Upgrade for Audi C8 OE 1-pot Rear Floating Calipers w/ePB. (Priced in Pair, Rotors are NOT included.)
      MSRP: $2,500.00
      Now: $2,375.00
    • Piston Kit (Stainless Steel) - Aston Martin, Mercedes AMG  Rear 4 pot calipers  (Price is for 2 Calipers)
      MSRP: $308.00
      Now: $292.00
    • Boots and Seals Kit - Mercedes AMG Rear 4 Piston Caliper (Price is for 2 Calipers)
      RB 4 Piston Caliper (170x43) for Corvette Rear (1 caliper)
      MSRP: $2,200.00
      Now: $2,090.00
