    • RB-CCB Rotor Conversion Kit (390x36mm) for Audi C7 (13-18) RS6/RS7) and ALL C7 Models (A/S/RS/Q) CCB Upgrade Conversion from Iron Rotors (P/N: 2R76)
  • front
  • RB-CCB Rotor Conversion Kit (390x36mm) for Audi C7 (13-18) RS6/RS7) and ALL C7 Models (A/S/RS/Q) CCB Upgrade Conversion from Iron Rotors (P/N: 2R76) front
    MSRP: $6,590.00
    Now: $6,260.00
    (You save $330.00 )
    AU-CRK-C7-390-CON
    This CCB rotor kit is designed for Audi C7 RS6/RS7 conversion upgrade to ccb with a direct swap to stock iron rotors.
    This kit also fits ALL Audi C7 models, those non RS6/RS7 owners must source their own 6 pot calipers.
    • 2 ea front CCB rotors (390x36mm)
    • 1 set ccb pads
    Rear iron rotor kit (optional)
    • 2 ea Rear 2 pc iron rotors (356x23 mm vs. OE 356x22)
    Feature & benefit:
    • Dramatic weight reduction
    • Literally no brake dust
    • Retain stock calipers and pads (w/ccb compound).
    • Direct bolt on installation.
    • Requires 19"/20" wheels
    • RS6/RS7 front OE/Brembo calipers are required to install the kit.
    Learn why RB-CCB rotors can perform better and last longer than OE/Brembo rotors.
    https://racingbrake.com/tech-info/
    • RB 2pc Rotor Kit (420/370) for Audi C7 (12-18) RS6/7 CCB to Iron Conversion (P/N 2584 & 2585) Front rotor
      Now: $4,056.50
    • RB 2pc Rotor Kit (400/370) for Audi C7 (12-18) RS6/7 CCB to Iron Conversion (P/N 2574 & 2585) Front wt.
      MSRP: $3,650.00
      Now: $3,460.00
    • 2R62 Rear kit w/oe caliper front oe iron rotor wt
      RB-CCB Rotor Kit (420/370) for Audi C8 (2019+) RS and Other Models (A/Q/S) Upgrade Conversion From Iron to CCB. Front & Rear (P/N: 2R54 & 2R62)
      MSRP: $13,600.00
      Now: $12,920.00
    • RB 2pc Rotor Kit (390/390) for Corvette C7 ( CCB to Iron Rotor Conversion) (P/N 2242 & 2368) RB 2pc Rotor Kit (390/390) for Corvette C7 ( CCB to Iron Rotor Conversion) (P/N 2242 & 2368)
      MSRP: $3,400.00
      Now: $2,990.00
    • RB-CCB Rotor Kit (420/370) for Audi C7 (12-18) RS6/7 CCB Replacement (P/N 2C95 & 2R10) RB-CCB Rotor Kit (420/370) for Audi C7 (12-18) RS6/7 CCB Replacement (P/N 2C95 & 2R10)
      MSRP: $13,500.00
      Now: $12,825.00
