    • RB 2pc Rotor Kit (394/360) CCB to Iron Conversion for Aston Martin DBS 11+ (2017+ w/128mm Bolt Hole Circle) Front and Rear (P/N 2699 & 2700)
  • Front Pad
  • Rear Pad
  • RB 2pc Rotor Kit (394/360) CCB to Iron Conversion for Aston Martin DBS 11+ (2017+ w/128mm Bolt Hole Circle) Front and Rear (P/N 2699 & 2700) RB 2pc Rotor Kit (394/360) CCB to Iron Conversion for Aston Martin DBS 11+ (2017+ w/128mm Bolt Hole Circle) Front and Rear (P/N 2699 & 2700) Front Pad Rear Pad
    MSRP: $3,800.00
    Now: $3,610.00
    (You save $190.00 )
    AM-IRK-394.360-127
    This rotor and pad kit is specially made for converting OE CCB rotors to Iron rotors for the late model (DB11 2017+) with a 100% bolt on installation. Not only it can eliminate that annoying squeaks from OE CCB rotors but lower your maintenance & replacement cost.
    Aston Martin later models (2017+) are identified to have a different caliper mouiting spread (200mm) and bolt hole circle (128mm):
    Please carefully verify your model/year before ordering. If you have an earlier model from early 2000 till 2016 (DB8/9/10), you should order this kit (w/114.3mm Bolt hole circle)
    Forum reviews:
    BG Stop Squeal: Finally a cure for Aston Martin Brake Squeal issues
    Converted from carbon ceramic to steel rotors. No more squeaking!!!!
    Kit contents:
    • 2 Front RB Iron Rotors
    • 2 Rear RB Iron Rotors
    • 1 set of front pads
    • 1 set of rear pads
    Replacement rotor ring:
    Front: D601-09
    Rear: D501-05
    Brake pads included in the kit and listed below are for street driving, for off-street applications please contact us for further details.
    Front: PD1395B
    Rear: PD1165
    • RB 2pc Rotor Kit (394/360) CCB to Iron Conversion for Aston Martin DB9, Vanquish, Virage, Vantage V12S;  Front and Rear (P/N 2409 & 2410) RB 2pc Rotor Kit (394/360) CCB to Iron Conversion for Aston Martin DB9, Vanquish, Virage, Vantage V12S;  Front and Rear (P/N 2409 & 2410)
      MSRP: $3,500.00
      Now: $3,325.00
      MSRP: $8,122.40
      Now: $7,716.28
    • [PD1395B-360] RB Brake Pads : Aston Martin Vantage Front w/CCB Rotors [PD1395B-360] RB Brake Pads : Aston Martin Vantage Front w/CCB Rotors
      MSRP: $834.90
      Now: $793.16
    • Carbon Ceramic Rotor Kit (394/360) for Aston Martin DB9, Vanquish, Vantage V12S CCB Rotor Replacement, Front & Rear (P/N 2C06 & 2C97) Carbon Ceramic Rotor Kit (394/360) for Aston Martin DB9, Vanquish, Vantage V12S CCB Rotor Replacement, Front & Rear (P/N 2C06 & 2C97)
      MSRP: $13,310.00
      Now: $12,644.50
      MSRP: $10,500.00
      Now: $9,975.00
