        • CROSS OVER TUBE
        • MIS. FITTINGS
      • All ACCESSORIES
      • CROSS OVER TUBE
      • MIS. FITTINGS
        • CROSS OVER TUBE
        • MIS. FITTINGS
    • RB CCB BBK (390/365) Bundle Kit (With 390/390 Option) for Tesla Plaid & LR Upgrade (PN 2R47 & 2R46) - Fits OE Calipers
      • All ACCESSORIES
      • CROSS OVER TUBE
      • MIS. FITTINGS
  • front kit installed
  • front clear 19"
  • front ccb wt
  • oe  front wt
  • rear ccb wt
  • RB CCB BBK (390/365) Bundle Kit (With 390/390 Option) for Tesla Plaid & LR Upgrade (PN 2R47 & 2R46) - Fits OE Calipers front kit installed front clear 19" front ccb wt oe  front wt rear ccb wt
    MSRP: $9,600.00
    Now: $9,120.00
    (You save $480.00 )
    TES-CRK-390.365
    Rotor & Pad Installation Video
    • 2 ea front  ccb rotors (bbk 390x32mm vs. OE 380x32)
    • 1 set front OE caliper spacers & mounting hardware.
    • 2 ea rear ccm rotors (stock 365x28mm, or bbk 390x28)
    • 1 set rear OE caliper bracket & mounting hardware (If bbk option is chosen).
    • 1 car set brake pads made for CCB rotors.
    • 1 car set rotor retaining screws.
    • SS brake line kit - Optional
    • Front kit - Fits OE 19" wheels w/o modification (front dust shield has room for 390mm rotors)
    • Rear kit - Require 20" or larger wheel and trim or removal of dust shield to install the kit due to the larger rotors.
    For tracking and racing application we recommend purchasing this RB-CCB System Big Brake Kit with oversized rotors for optimal performance and durability.
    Weight reduction:
    OE IRON 28.2 22.5 50.7 101.4
    RB CCM BBK*
    13.8 11.8 25.6 51.2
    WT SAVING
    14.4
    10.7
    25.1
    50.2(49.5%
    *Rear wt based on 365x28mm
    This CCM rotor BBK is specially developed for Tesla Plaid & Long Range upgrade from stock iron rotors. They are made for an easy installation and 100% compatible with OE calipers (including the OE calipers and pads for ePB)
    • Easy to install.
    • All discs are made with RB Gen 4 CCM technology; long (continuous) carbon fibers and angle vanes.
    • CCM rotors have "Diamond hard" surface with excellent "Thermal Stability" so they will NEVER Wear*, Warp, or Crack like conventional iron rotors due to the heat. More advantageous for tracking/racing with proper brake pads.
    • Literally no brake dust.
    • Improve driving comfort.
    What's the difference between the front rotors in this kit vs. the economy kit using Corvette C7 ZR1 discs (2R47-ZR1)?
    Compare rotor material RB - Continuous fibers vs. OE/Brembo's chopped fibers
    In Cooling Vanes - Angle (directional) vs. Straight (Better cooling efficiency)
    In Finish - Fully machined vs. as casted (Better look and balance)
    Avoid:
    Learn more about the different generation on CCM rotors.
    • Save 10% on RB CCB BBK Bundle (410/365) with Optional Rear BBK for Tesla X Plaid (PN 2R57 & 2R46) - Fits OE Calipers oe front wt
      MSRP: $13,460.00
      Now: $12,970.00
    • Save 10% on OE Caliper BBK (390/365) for Tesla X Plaid Stock Replacement Front & Rear (P/N 2684 & 2435P) Front 390
      MSRP: $3,295.00
      Now: $2,870.00
    • Kit contents Front Kit
      MSRP: $4,125.00
      Now: $3,920.00
    • front front
      MSRP: $16,565.00
      Now: $15,786.75
      Now: $12,400.00
