How RB two piece rotors compare to the competitions:
| RB | Competition | Feature Comparison | RB Benefit | |
| Rotor Design | Center Mount | Surface Mount | Center Mount admits cool air from both IB & OB vs. IB only | Cooler brake |
| Rotor Hat Material (Al) | Forged | Extruded | Forged aluminum is stronger (BHN~115) vs. extrusion (95) | Stiffer and Stronger |
| Hadware Assembly | Self-locking (M6) | Use Loctite (M5) | M6 vs. M5 bolts; 2pc vs. Multiple pieces | Self-locking provides consistent torque at any temperature |
| Disc Material (CI) | SAE G3500 BHN~190-220 | ? | Certified casting hardness vs. unknown | Harder iron= higher strength & durability for consitent brake torque delivery |
| Disc Treatment | Heat Treated | ? | Heat treatred casting vs. unknown | Reduce the chance of warping & cracking during heat cycles |
| Rear Rotor Hat | Has iron sleeve for drum emergency braking | ? | RB rear rotor is 100% compatible with OE drum brake | Not just make to fit brake shoe, RB is 100% compatible with OE rear drum brake |
How RB rear two piece rotors are made differently from others
RB Center-Mount 2 piece Rotor Advantage Over Conventional Surface Mount.
1. RB two piece rotor runs cooler than competitions
2. RB uses less components:
RB Center Mount design provides widely open & Un-restricted "Air Ports" from both Inboard and outboard while other brake companies try to achieve the same by "directional hats". Without regarding how effective it is, they need 4 components (2 hats, 2 discs) for a pair of rotor vs. RB's 2 components (1 hat, 1 disc-unidirectional)
Brembo
Stoptech - Requires 4 different components (2 hats, 2 discs) for a set of directional rotor vs. others' 3 components (1 hat, 2 discs), vs. RB center-mount design (1 hat, 1 disc)
3. RB center mount design saves installation space and allow using a deeper pad w/o interfering with the hardware.
4. RB self-locking design w/o using loctite so to retain torque consistent at any braking temperature:
4. Rotor Treatments:
Disc is heat-treated before machining to minimize the rotor from warping during the extreme heat cycles.
Rotor surfaces are treated by EDP with Black Paint, so all the internal vanes, corners, crevices are penetrated with a uniform coat, unlike plating which can only reach the external surfaces.
With only a few stops the black paint where the pads in contact, will disappear and show in metallic finish while the rest surface / area remain protected from corrosion, so the rotor will have a nice look for the rest of life w/o undesirable rusty area like OE or others.
RB Rotor:
After Installed:
After a few stops:
See the complete review here (Corvette ZR1 CCB to iron rotor conversion)
[ZR1] light weight steel rotor replacement
Trackhawk/WK2 OE two piece:
