Quick view [PD-ZR1-360] Brake Pads for CCM Rotors - Corvette ZR1, Camaro Z28, Viper ACRE, Ferrari F458/California & 488, Alfa Rome, Nissan GT-R (w/RB rotors) & RB 6/4 Caliper Kit - FRONT & REAR: (PD1395 & PD1165) MSRP: Was: Now: $1,050.00 Choose Options Compare Quick view GM/Brembo CCB Brake Kit (394/390) for Camaro G6 2016+ & Cadillac V3 Upgrade (P/N 2C85 & 2C86) MSRP: $15,600.00 Was: Now: $14,820.00 Choose Options Compare Quick view RB Light Wt Rotor Hat for Camaro G5 Z28 Rear & G6 Upgrade to CCM Rotors (390x32mm) w/Z28 Calipers only - Not compatible with G6 Rear Calipers (2 ea. Incl. Hardware Set) MSRP: $1,936.00 Was: Now: $1,839.20 Add to Cart Compare Quick view RB Rotor Hats for Camaro G6 & Cadillac V3 Front Converting to Z28/C06 ZR1 CCM Rotors (394x36mm) - 2 ea. Incl. Hardware Kit MSRP: $1,560.00 Was: Now: $1,482.00 Add to Cart Compare Quick view RB-CCB Rotor Kit (394/360) for Camaro G6 (2016+) ZL1, 1LE & Cadillac V3 Conversion Upgrade Fits OE Calipers (P/N 2C85 & 2R12) MSRP: $13,000.00 Was: Now: $12,350.00 Choose Options Compare Quick view RB-CCB System Kit (394/390) for Camaro G6 & Cadillac V3 (P/N 2C85-K & 2C86-K) MSRP: $16,800.00 Was: Now: $15,960.00 Add to Cart Compare Quick view [PD-ZR1-360] Brake Pads for CCM Rotors - Corvette ZR1, Camaro Z28, Viper ACRE, Ferrari F458/California & 488, Alfa Rome, Nissan GT-R (w/RB rotors) & RB 6/4 Caliper Kit - FRONT & REAR: (PD1395 & PD1165) Installation Note: For Ford GT350 6 pot calipers installation it requires a hardware kit (included on request) to create proper tension from the hold down spring to the brake pads to avoid rattling. Brembo OE ZR1 brake pad dimension flow as seen on... MSRP: Was: Now: $1,050.00 Choose Options Compare Quick view GM/Brembo CCB Brake Kit (394/390) for Camaro G6 2016+ & Cadillac V3 Upgrade (P/N 2C85 & 2C86) This kit includes the following: 2 ea Front CCM rotors (394x36mm) 2 ea Rear CCM rotors (390x32mm) - Light wt RB hats option available 2 ea Rear 4 pot brand new calipers - Red color option available 1 set street pads for CCB rotors 1 car set of stainless... MSRP: $15,600.00 Was: Now: $14,820.00 Choose Options Compare Quick view RB Light Wt Rotor Hat for Camaro G5 Z28 Rear & G6 Upgrade to CCM Rotors (390x32mm) w/Z28 Calipers only - Not compatible with G6 Rear Calipers (2 ea. Incl. Hardware Set) Kit includes: 2 ea light wt composite hats. 20 sets hardware kits OE Stainless Steel Hat:RB Composite Hat: MSRP: $1,936.00 Was: Now: $1,839.20 Add to Cart Compare Quick view RB Rotor Hats for Camaro G6 & Cadillac V3 Front Converting to Z28/C06 ZR1 CCM Rotors (394x36mm) - 2 ea. Incl. Hardware Kit This hat kit (2 ea) includes all the hardware you need by switching the rotor hats from OE ZR1/Z28 front rotor assembly so you can have an instant upgrade to CCM rotors. Note: Discs are not included in the price, you must purchase from GM dealers or... MSRP: $1,560.00 Was: Now: $1,482.00 Add to Cart Compare Quick view RB-CCB Rotor Kit (394/360) for Camaro G6 (2016+) ZL1, 1LE & Cadillac V3 Conversion Upgrade Fits OE Calipers (P/N 2C85 & 2R12) Installation note: Our rear rotor are mode to 30mm thickness (vs. OE 28mm) for extra large volume and thermal capacity due to iron rotor conversion, which will still fit under OE calipers w/o any issue or concern as long as your pads are no thicker than... MSRP: $13,000.00 Was: Now: $12,350.00 Choose Options Compare Quick view RB-CCB System Kit (394/390) for Camaro G6 & Cadillac V3 (P/N 2C85-K & 2C86-K) Kit contains: 2 ea. RB 6-piston caliper 2 ea. RB 4-piston caliper 2 ea. Front CCM rotor 2 ea. Rear CCM rotor 1 car set brake pads 1 car set brake lines MSRP: $16,800.00 Was: Now: $15,960.00 Add to Cart Compare Compare Selected × OK
