- 2 ea front ccb rotors (390x34)-Select option to oversize the front rotors to 394x36mm
- 2 ea front RB 6 pot heavy duty calipers
- 2 ea rear ccb rotors (390x32)-Oversize from OE's 350x28mm
- 1 car set caliper adaptors
- 1 car set ccb brake pads
- 1 car set brake lines
ST600 brake pad performance characteristics:
- Consistent COF (Coefficient of Friction)
- Wider range of operating temperature
- Excellent modulation
- Literally no dust
- No squeak
- Highly durable
- Front: PD1395-360
- Rear: PD1165-360
RB rear rotor hats are made with iron sleeve liner and is fully compatible with OE rear drum brakes w/o having to delete it like other aftermarekt two piece rotors, or only machined from aluminum that can score and destroy the rotor hats if the parking brake is not released.
