Quick view Brake Line - Tesla Model S/X Plaid Front & Rear MSRP: $250.00 Was: Now: $237.50 Choose Options Compare Quick view OE Caliper BBK (410/390) for Tesla S/X Plaid Front and Rear (P/N 2681 & 2643) MSRP: $4,125.00 Was: Now: $3,920.00 Choose Options Compare Quick view RB (XT-970) Track Pads for Tesla Model S/X Plaid & LR Front & Rear - (P/N PDTS2021, PD1929) MSRP: $490.00 Was: Now: $465.00 Choose Options Compare Quick view RB (XT910) Street Pads for Tesla Model S/X Plaid & LR Front & Rear - [PDTS2021-PD1929] MSRP: $445.00 Was: Now: $423.00 Choose Options Compare Quick view RB 2 pc Rotor Kit (380/365) for Tesla Plaid Stock Replacement Front & Rear (P/N 2679 & 2435) MSRP: $2,900.00 Was: Now: $2,755.00 Choose Options Compare Quick view RB 65mm Lining Depth (Large) Pads for Tesla Model S/X Plaid & LR Front OE Calipers; For big rotors with 66mm or wider annulus only. (NOT compatible with stock rotors) MSRP: $337.00 Was: Now: $320.00 Choose Options Compare Quick view RB System BBK (432/410) for Tesla S Plaid & LR; Front RB Calipers & Rear OE Calipers (Not Included) (P/N 2682-K & 2683-K) MSRP: $8,400.00 Was: Now: $7,980.00 Choose Options Compare Quick view Save 10% on OE Caliper BBK (390/365) for Tesla X Plaid Stock Replacement Front & Rear (P/N 2684 & 2435P) MSRP: $3,295.00 Was: Now: $2,870.00 Choose Options Compare Quick view Brake Line - Tesla Model S/X Plaid Front & Rear MSRP: $250.00 Was: Now: $237.50 Choose Options Compare Quick view OE Caliper BBK (410/390) for Tesla S/X Plaid Front and Rear (P/N 2681 & 2643) Kit includes: 2 ea - Front oversized 2pc rotors 410x33mm vs. stock 380x32 (Plaid S) or 390x32 (Plaid X) 1 set - Front caliper spacer and hardware kit 2 ea - Rear oversized 2pc rotors 390x28mm or 410x30mm vs. stock 365x28 - Select at option 1 set - Rear... MSRP: $4,125.00 Was: Now: $3,920.00 Choose Options Compare Quick view RB (XT-970) Track Pads for Tesla Model S/X Plaid & LR Front & Rear - (P/N PDTS2021, PD1929) Forum review: Racing Brake XT910 vs XT970 MSRP: $490.00 Was: Now: $465.00 Choose Options Compare Quick view RB (XT910) Street Pads for Tesla Model S/X Plaid & LR Front & Rear - [PDTS2021-PD1929] Forum review: Racing Brake XT910 vs XT970 MSRP: $445.00 Was: Now: $423.00 Choose Options Compare Quick view RB 2 pc Rotor Kit (380/365) for Tesla Plaid Stock Replacement Front & Rear (P/N 2679 & 2435) ATTENTION!!! Purchase of this stock replacement kit provides you a seamless upgrade to this (410/390mm) BBK by replacing only the rotor rings and adding caliper spacers/brackets. Very flexible - upgrade as you need. Retain the original rotor hats &... MSRP: $2,900.00 Was: Now: $2,755.00 Choose Options Compare Quick view RB 65mm Lining Depth (Large) Pads for Tesla Model S/X Plaid & LR Front OE Calipers; For big rotors with 66mm or wider annulus only. (NOT compatible with stock rotors) The benefit of a larger pad with a larger pad provides a "Larger Volume" (~25% more than OE) in friction material and can run the braking at lower temperature vs. the smaller pads (OE size), reduce the components wear and replacement (rotor, pad,... MSRP: $337.00 Was: Now: $320.00 Choose Options Compare Quick view RB System BBK (432/410) for Tesla S Plaid & LR; Front RB Calipers & Rear OE Calipers (Not Included) (P/N 2682-K & 2683-K) This kit is specially developed for Model S 2021+ Plaid Upgrade for the ultimate track duty: Front calipers are RB6L 6 pot staggered pistons built for heavy track duty - Same calipers as our offer for OE/Brembo replacement calipers for GTR, Mustang... MSRP: $8,400.00 Was: Now: $7,980.00 Choose Options Compare Quick view Save 10% on OE Caliper BBK (390/365) for Tesla X Plaid Stock Replacement Front & Rear (P/N 2684 & 2435P) Kit includes: 2 ea Front 2pc rotors (390x33 vs. 390x32) 1 set Front caliper spacer & hardware kit. 2 ea Rear 2pc rotors (365x28 = stock) 1 set street pads. 1 set of retaining screws. ROTOR WT. COMPARISON... MSRP: $3,295.00 Was: Now: $2,870.00 Choose Options Compare Compare Selected × OK
