Quick view sku: BL073 Front and Rear Stainless Steel Brake Line Set for Ford Mustang GT350>350R 2015-18 (OEM Caliper Fitment) MSRP: $290.00 Now: $275.00 Add to Cart Compare Quick view sku: FOR-IRK-380.380 RB 2pc Rotor Kit (380/380) for Ford Mustang Shelby GT350 2016+ Downsized from stock for Track Racing (delete rear drum brake) (P/N 2611 & 2612) MSRP: $3,025.00 Now: $2,873.75 Choose Options Compare Quick view sku: FOR-IRK-394.380 RB 2pc Rotor Kit (394/380) for Ford Mustang Shelby GT350 2016+ Stock Replacement Front & Rear (P/N 2568 & 2569) MSRP: $3,152.41 Now: $2,994.79 Choose Options Compare Quick view sku: FOR-IRP-380.380 RB Caliper Kit (380/380) for Ford Mustang GT350 Track Racing. Rear rotors are not compatible with OE drum parking brake - See disclaimer under description MSRP: $7,920.00 Now: $7,524.00 Choose Options Compare Quick view Front and Rear Stainless Steel Brake Line Set for Ford Mustang GT350>350R 2015-18 (OEM Caliper Fitment) MSRP: $290.00 Now: $275.00 Add to Cart Compare Quick view RB 2pc Rotor Kit (380/380) for Ford Mustang Shelby GT350 2016+ Downsized from stock for Track Racing (delete rear drum brake) (P/N 2611 & 2612) ROTOR WT. COMPARISON (LBS) per rotor FRONT REAR OE 30.3 19.1 RB 26.5 18.5 Kit includes: 2 ea front rotors (380x36 vs. OE 394x36mm) 2 ea rear rotors (380x28 vs. OE 380x26mm) 1 set brake pads (optional) This rotor kit is specially develped... MSRP: $3,025.00 Now: $2,873.75 Choose Options Compare Quick view RB 2pc Rotor Kit (394/380) for Ford Mustang Shelby GT350 2016+ Stock Replacement Front & Rear (P/N 2568 & 2569) ROTOR WT. COMPARISON (LBS) per rotor FRONT REAR OE 30.3 19.1 RB 29.3 17 Wt. Saving 1.0 2.1 Kit includes: 2 ea front rotors 2 ea rear rotors (Retains OE emergency drum brakes) 1 set brake pads (optional) Brake pads included in the kit is for... MSRP: $3,152.41 Now: $2,994.79 Choose Options Compare Quick view RB Caliper Kit (380/380) for Ford Mustang GT350 Track Racing. Rear rotors are not compatible with OE drum parking brake - See disclaimer under description This racing brake kit is specially made for track racing so that you can possibly run on 18" aftermarket wheels (download wheel fitment to verify), as a result the rear rotor hat can no longer accomondate the OE drum brake (ID=227mm) which must be... MSRP: $7,920.00 Now: $7,524.00 Choose Options Compare Compare Selected × OK
