Quick view Big Brake Kit (OE Caliper, Slot) - JETTA VR6, 1.8T FRONT 99-04 MSRP: $447.70 Was: Now: $425.32 Compare Quick view Brake line Kit - VW MK5 for RB Caliper BBK and OE Replacement (03-08) MSRP: $175.00 Was: Now: $166.25 Choose Options Compare Quick view RB 2pc Rotor Kit (300x25mm) for VW Jetta/GTi (VR-6) FRONT 93-98 MSRP: $817.30 Was: Now: $776.44 Add to Cart Compare Quick view RB 2pc Rotors (330/308) for VW MK4 R32 2004 Front & Rear OE Caliper BBK (P/N: 2174/2353) MSRP: $1,800.00 Was: Now: $1,710.00 Choose Options Compare Quick view RB 2pc Rotors for VW MK4 R32 2004 Front MSRP: $896.50 Was: Now: $851.68 Compare Quick view RB 4 Pot Caliper BBK (330x30mm) for MK4 (99-04) Front MSRP: $2,604.80 Was: Now: $2,474.56 Choose Options Compare Quick view RB BBK (348x32) for VW M5/M6 Front w/18Z Caliper MSRP: $3,010.70 Was: Now: $2,860.17 Compare Quick view RB Rotor Kit (322x30) for VW MK5 / MK6 Front Upgrade w/17Z Calipers (Calipers & Brake LInes Are for Illustration purpose only and are NOT Included - Customer must acquire their own) MSRP: $1,105.00 Was: Now: $1,050.00 Choose Options Compare Quick view Big Brake Kit (OE Caliper, Slot) - JETTA VR6, 1.8T FRONT 99-04 This kit includes: 2 ea. alloyed one-piece rotors (90781) 2 ea. Extended high strength brackets ( MSRP: $447.70 Was: Now: $425.32 Compare Quick view Brake line Kit - VW MK5 for RB Caliper BBK and OE Replacement (03-08) This brake line kit comes with all the necessary components for a complete installation for front and rear axles. These lines are built to RB specifications, meeting D.O.T. Certification. Upgrade to stainless steel braided to improve brake response and... MSRP: $175.00 Was: Now: $166.25 Choose Options Compare Quick view RB 2pc Rotor Kit (300x25mm) for VW Jetta/GTi (VR-6) FRONT 93-98 Rotor Material: Racing Formula Alloyed Gray Iron & Heat treatedMachining: Straight SlotSurface: EDP Coating w/cross cut grinding on friction surface NOTE: Retaining and jack screw holes might have been eliminate MSRP: $817.30 Was: Now: $776.44 Add to Cart Compare Quick view RB 2pc Rotors (330/308) for VW MK4 R32 2004 Front & Rear OE Caliper BBK (P/N: 2174/2353) Replacement rotor rings: Front: D300-01 Rear: D200-07 MSRP: $1,800.00 Was: Now: $1,710.00 Choose Options Compare Quick view RB 2pc Rotors for VW MK4 R32 2004 Front COMPLETE KIT LINK: VW-IRK-03 Rotor wt: 18.5 lbs Replacement rotor rings: D300-01 MSRP: $896.50 Was: Now: $851.68 Compare Quick view RB 4 Pot Caliper BBK (330x30mm) for MK4 (99-04) Front Replacement rotor ring: D305-02 Replacement pads: PD647 Wheel fitment template: 2187-K MSRP: $2,604.80 Was: Now: $2,474.56 Choose Options Compare Quick view RB BBK (348x32) for VW M5/M6 Front w/18Z Caliper NOTE: Brake pads are brake sens MSRP: $3,010.70 Was: Now: $2,860.17 Compare Quick view RB Rotor Kit (322x30) for VW MK5 / MK6 Front Upgrade w/17Z Calipers (Calipers & Brake LInes Are for Illustration purpose only and are NOT Included - Customer must acquire their own) Kit contents: 2 ea 2 pc rotors specifically made for this retrofit upgrade. Brake pads - Optional Brake calipers/Brake lines are NOT included. Replacement brake pad: PD1007-35 (For 17Z caliper) Replacement discs: Front: D300-04 (322x30) Installation... MSRP: $1,105.00 Was: Now: $1,050.00 Choose Options Compare Compare Selected × OK
