Quick view Big Brake Kit (4-pot, Slot) - LEGACY (2.5 GT, spec.B) FRONT 05-09 MSRP: $2,522.30 Was: Now: $2,396.19 Add to Cart Compare Quick view Big Brake Kit (OE Caliper, Slot) - LEGACY REAR (4WD TURBO) 90-94 MSRP: $537.90 Was: Now: $511.01 Add to Cart Compare Quick view Big Brake Kit (OE Caliper, Slot) - LEGACY REAR (4WD TURBO) 90-94 AND OTHER SUBARU REAR 316X18mm MSRP: $650.00 Was: Now: $617.50 Choose Options Compare Quick view Big Brake Kit (OE Caliper, Slot) - LEGACY REAR (NON 4WD TURBO) 90-06 AND OTHER SUBARU REAR 290X18mm MSRP: $599.50 Was: Now: $569.53 Add to Cart Compare Quick view Big Brake Kit (OE Caliper, Slot) - LEGACY REAR (NON 4WD TURBO) 90-06 AND OTHER SUBARU REAR 318X18mm MSRP: $789.80 Was: Now: $750.31 Add to Cart Compare Quick view Caliper Brackets - For Subaru Rear BBK Upgrade to Legacy 2.5GT w/316x18 mm Rotors - Price per pair (x2) MSRP: $305.00 Was: Now: $289.75 Add to Cart Compare Quick view RB 2 pc Rotor - LEGACY (2.5 GT, spec.B) FRONT 05-09 MSRP: $1,024.10 Was: Now: $972.90 Add to Cart Compare Quick view RB 2 pc Rotor for LEGACY 2.5 GT FRONT 05-09 MSRP: $833.80 Was: Now: $720.99 Choose Options Compare Quick view RB BBK (322x25) for Subaru BRZ, Scion FR-S, GT86 Front MSRP: $2,490.00 Was: Now: $2,365.00 Compare Quick view Big Brake Kit (4-pot, Slot) - LEGACY (2.5 GT, spec.B) FRONT 05-09 This kit includes: 2 Two-piece center-mount rotors 2 RB 4-Piston calipers MSRP: $2,522.30 Was: Now: $2,396.19 Add to Cart Compare Quick view Big Brake Kit (OE Caliper, Slot) - LEGACY REAR (4WD TURBO) 90-94 This Kit Includes: 2 ea. Alloyed one-piece rotors (9152-111) 2 ea. Extended high strength brackets MSRP: $537.90 Was: Now: $511.01 Add to Cart Compare Quick view Big Brake Kit (OE Caliper, Slot) - LEGACY REAR (4WD TURBO) 90-94 AND OTHER SUBARU REAR 316X18mm Kit Contents Option: 2 ea Rotors (318x16mm) Alloyed and ventilated. 2 ea Upgrade BBK brackets (Optional) - For non Turbo owners. 1 set Brake pads (Optional) MSRP: $650.00 Was: Now: $617.50 Choose Options Compare Quick view Big Brake Kit (OE Caliper, Slot) - LEGACY REAR (NON 4WD TURBO) 90-06 AND OTHER SUBARU REAR 290X18mm This kit is a +1 kit for vehicles with 290x18mm rotors. This kit fits the following vehicles:LEGACY REAR (NON 4WD TURBO) 90-06FORESTER REAR 98-09OUTBACK REAR 95-09 The rotors in this brake kit are 18mm thic MSRP: $599.50 Was: Now: $569.53 Add to Cart Compare Quick view Big Brake Kit (OE Caliper, Slot) - LEGACY REAR (NON 4WD TURBO) 90-06 AND OTHER SUBARU REAR 318X18mm This kit is a +2 kit for vehicles with 266x10mm stock rotors and a +1 kit for vehicles with 290x10mm rotors. This kit fits the following vehicles:LEGACY REAR (NON 4WD TURBO) 90-06FORESTER REAR 98-09OUTBACK REAR 95-09 MSRP: $789.80 Was: Now: $750.31 Add to Cart Compare Quick view Caliper Brackets - For Subaru Rear BBK Upgrade to Legacy 2.5GT w/316x18 mm Rotors - Price per pair (x2) This bracket allows you to upgrade your Subaru rear rotors to Legacy 2.5GT 316x18 mm rotors. Replacement Rotors for this brake kit: P/N: 9160-01 MSRP: $305.00 Was: Now: $289.75 Add to Cart Compare Quick view RB 2 pc Rotor - LEGACY (2.5 GT, spec.B) FRONT 05-09 Replacement rotor ring: D215-04 MSRP: $1,024.10 Was: Now: $972.90 Add to Cart Compare Quick view RB 2 pc Rotor for LEGACY 2.5 GT FRONT 05-09 Kit contains: 2 ea two piece rotors Disc finish available (Select at option): Surface Slots - 311 Drill & Slots - 351 MSRP: $833.80 Was: Now: $720.99 Choose Options Compare Quick view RB BBK (322x25) for Subaru BRZ, Scion FR-S, GT86 Front This Brake Kit Is Obsolete & Superseded by P/N 2567-K (332x28mm)! If you purchased this BBK (322x25mm) in early 2000 and are looking for replacement rotor rings, be advised they are no longer available, instead you should puchase a new rotor assembly... MSRP: $2,490.00 Was: Now: $2,365.00 Compare 1 2 Next 1 2 Next Compare Selected × OK
