Quick view [PD-ZR1-360] Brake Pads for CCM Rotors - Corvette ZR1, Camaro Z28, Viper ACRE, Ferrari F458/California & 488, Alfa Rome, Nissan GT-R (w/RB rotors) & RB 6/4 Caliper Kit - FRONT & REAR: (PD1395 & PD1165) MSRP: Was: Now: $1,050.00 Choose Options Compare Quick view GM OE CCM Rotors (390x32) for Camaro G5 Z28 Rear (M14 Lug bolt) Price is for 2 Rotors MSRP: $4,730.00 Was: Now: $4,493.50 Compare Quick view GM/Brembo CCB Brake Kit (394/390) for Camaro G5 (10-15) & CTSV V2 Upgrade (PN: 2C38 & 2C86) MSRP: $14,500.00 Was: Now: $13,800.00 Choose Options Compare Quick view RB 2pc "Lightweight" Rotor Kit (390x32/390x30) for Camaro Z28 CCB to Iron Rotor Conversion (P/N 2416 & 2382) MSRP: Was: Now: $3,383.00 Choose Options Compare Quick view RB 2pc Rotor Kit (390x36/390x30) for GM Camaro Z28 ccb to Iron Conversion (P/N 2355 & 2382) MSRP: $3,100.00 Was: Now: $2,945.00 Choose Options Compare Quick view RB Light Wt Rotor Hat for Camaro G5 Z28 Rear & G6 Upgrade to CCM Rotors (390x32mm) w/Z28 Calipers only - Not compatible with G6 Rear Calipers (2 ea. Incl. Hardware Set) MSRP: $1,936.00 Was: Now: $1,839.20 Add to Cart Compare SALE Quick view RB-CCB Carbon Ceramic Rotor Kit (394/390) for Camaro Z28 Replacement Front & Rear (P/N: 2C38 & 2C83) MSRP: $13,000.00 Was: $12,500.00 Now: $11,250.00 Choose Options Compare Quick view RB-CCB Disc (390x32x66mm) - Price per pair. MSRP: $4,490.00 Was: Now: $4,266.00 Choose Options Compare Quick view RB-CCB Disc (394x36x89mm) - Price per pair. MSRP: $4,850.00 Was: Now: $4,607.50 Choose Options Compare Quick view [PD-ZR1-360] Brake Pads for CCM Rotors - Corvette ZR1, Camaro Z28, Viper ACRE, Ferrari F458/California & 488, Alfa Rome, Nissan GT-R (w/RB rotors) & RB 6/4 Caliper Kit - FRONT & REAR: (PD1395 & PD1165) Installation Note: For Ford GT350 6 pot calipers installation it requires a hardware kit (included on request) to create proper tension from the hold down spring to the brake pads to avoid rattling. Brembo OE ZR1 brake pad dimension flow as seen on... MSRP: Was: Now: $1,050.00 Choose Options Compare Quick view GM OE CCM Rotors (390x32) for Camaro G5 Z28 Rear (M14 Lug bolt) Price is for 2 Rotors 1. Rotors are brand new & unused. 2. Drawing picture shown the rotor assembly with RB light weight hats, and is for showing dimensions only, OE rotors come with stainless steel hats. MSRP: $4,730.00 Was: Now: $4,493.50 Compare Quick view GM/Brembo CCB Brake Kit (394/390) for Camaro G5 (10-15) & CTSV V2 Upgrade (PN: 2C38 & 2C86) Kit contents: 2 ea. Front Z28 6-piston calipers 2 ea. Rear Z28 4-piston calipers 2 ea. Front CCM rotors - OE Brembo (Option RB long carbon fibers) 2 ea. Rear CCM rotors - OE Brembo (Optional RB long carbon fibers) 1 car set street pads 1 car set brake... MSRP: $14,500.00 Was: Now: $13,800.00 Choose Options Compare Quick view RB 2pc "Lightweight" Rotor Kit (390x32/390x30) for Camaro Z28 CCB to Iron Rotor Conversion (P/N 2416 & 2382) Installation notes: 100% Bolt on installations Rotor kit is custom made for Z28 ccb conversion to iron rotors Extremely "lightweight" (22.5 lbs) front rotors can save 3 lbs per rotor over standard iron conversion (390x36mm @25.7 lbs) If you are... MSRP: Was: Now: $3,383.00 Choose Options Compare Quick view RB 2pc Rotor Kit (390x36/390x30) for GM Camaro Z28 ccb to Iron Conversion (P/N 2355 & 2382) Installation Note: 100% bolt on w/o any modifications. Direct conversion from OE ccb to iron rotors Rear rotor hats are 100% emergency drum brake compatible Kit includes: 2 ea front 2 pc rotors (390x36 vs. OE ccb 394x36mm) - 390mm is the actual pad... MSRP: $3,100.00 Was: Now: $2,945.00 Choose Options Compare Quick view RB Light Wt Rotor Hat for Camaro G5 Z28 Rear & G6 Upgrade to CCM Rotors (390x32mm) w/Z28 Calipers only - Not compatible with G6 Rear Calipers (2 ea. Incl. Hardware Set) Kit includes: 2 ea light wt composite hats. 20 sets hardware kits OE Stainless Steel Hat:RB Composite Hat: MSRP: $1,936.00 Was: Now: $1,839.20 Add to Cart Compare SALE Quick view RB-CCB Carbon Ceramic Rotor Kit (394/390) for Camaro Z28 Replacement Front & Rear (P/N: 2C38 & 2C83) Kit includes: 2 ea Front ccb rotors (394x36mm) 2 ea Rear ccb rotors (390x32mm) 1 car set CCB brake pads (Optional) Feature & benefits: Discs are made of long carbon fibers (vs.. OE/Brembo Chopped fibers) for improved performance & lasting... MSRP: $13,000.00 Was: $12,500.00 Now: $11,250.00 Choose Options Compare Quick view RB-CCB Disc (390x32x66mm) - Price per pair. Discs are made for a direct replacement to OE/Brembo with long carbon fibers. See tech info. MSRP: $4,490.00 Was: Now: $4,266.00 Choose Options Compare Quick view RB-CCB Disc (394x36x89mm) - Price per pair. Discs are made with long carbon fibers for a direct replacement to OE/Brembo ccb front rotors for Corvette ZR1 C6, C7, Camaro Z28, McLaren 570, Aston Martin, Alfa Romeo etc. See tech info. Advantage: Reuse OE hats and hardware 100% interchangeable with... MSRP: $4,850.00 Was: Now: $4,607.50 Choose Options Compare 1 2 Next 1 2 Next Compare Selected × OK
