Feature Comparision
Two-piece rotors |
| Feature Comparison Compare the features between the competition & RB two-piece rotors, also describes the benefits. |
One-piece rotors |
| Feature Comparison Compare the features between the competition & RB one-piece rotors, also describes the benefits. |
| Upgraded Curved Vanes Selected applications are upgraded to curved (directional) vanes from OE straight vane to improve air flow. |
Feature Comparison - One-piece Rotors
| Features | Competition | RB Rotors | Benefits |
| Design | Duplicate from OE sample for aftermarket replacement. | 3D modeling assures dimensional accuracy with improved, patented designs for optimum performance. | - Reinforced ribs reduce warpage. - Convergent vane keeps disc cooler. - Open slots vent gas and debris w/o buildup. |
| Material | Standard aftermarket replacement. | Casting based on performance formula. | Increased longevity and higher resistance to warping. |
| Machining | Modified from shelf stock. | Rotors are machined with tight tolerances in parallelism, thickness variation and run out. Cross drilling and slotting are part of the production process. | RB rotors have total performance integrity - from design to finish. |
| Dynamic Balancing | May or may not be done. Cross-drilling is often done after the balancing step, which may result in an imbalanced rotor. | 100% checked and corrected as needed for all ventilated rotors. | To assure pulsation free pedal feel. |
| Surface Coating | Cadmium, Zinc plating or None. | ElectroDeposition Paint (EDP) | EDP offers better resistance to corrosion with uniform surface coverage on both edges and recesses (inside vanes). Better appearance and more environmental friendly. |
| Friction Surface Finish | Plating is the final step. Friction surface remains plated. | Final process cross cut grinding, which is performed after surface coating. | Tightest tolerance is assured by correcting any possible distortion during surface treatment. Aids in pad break-in. |
| Quality Assurance | May or may not have QA procedures. | Our company name, part number, minimum thickness, lot number, and or production date code are imprinted. | Symbol of quality, identification, and traceability. |
Feature Comparison - Two-piece Rotor (Center-mount)
| Features | Competition | RacingBrake | Benefit |
| Vane configuration | Traditional curve | Convergent curve (Learn more...) | Circulate air more efficiently for better cooling |
| Air inlet | Inboard only | Both inboard and outboard | Much cooler disc |
| Disc to hat mount | On surface | On center | Balanced stress load |
| Rotation direction | Directional (left or right) | Uni-directional (left & right) | Installer friendly and less inventory |
| Disc Material | Standard G3000 material - 30,000 psi of tensile strength. | G3500 racing formula (35,000 psi of tensile strength) and heat treated | More resistant to wear and warpage |
| Finish | Drill or slot | Slotted, Drilled&Slotted, or Open slot available (Learn more...) | Open slots improve cooling, prevent cracking, and vent gas and debris without build up |
| Surface coating | Bare or zinc plating | EDP coating | EDP offers better resistance to corrosion with uniform surface coverage on both edges and recesses (inside vanes). Better appearance and more environmental friendly. |
| Rotor hat | Cut from billet | Forged aluminum alloy | Provides better strength & stiffness |
| Fastener/hardware | Use washer and glue | Use self-locking nuts (Learn more...) | Positive locking w/o annoying rattling. No threadlocker. Easy to assemble and remove. |
| Warranty | N/A | 6 month | Protection against cracking or warpage (read more) |
Curved Vane
The following applications are upgraded to curved (directional vanes) from OE straight vane to improve air flow and therefore make the rotor run much cooler.
| P/N | Make | Model | Year | Application | Position | Side |
| 90761 | ACURA | CL COUPE | 01-03 | 3.2 V6 | FRONT | Left |
| 90762 | ACURA | CL COUPE | 01-03 | 3.2 V6 | FRONT | Right |
| 90761 | ACURA | MDX | 01-04 | FRONT | Left | |
| 90762 | ACURA | MDX | 01-04 | FRONT | Right | |
| 90761 | ACURA | TSX | 2004 | FRONT | Left | |
| 90762 | ACURA | TSX | 2004 | FRONT | Right | |
| 90071 | ACURA | NSX | 97-04 | FRONT | Left | |
| 90072 | ACURA | NSX | 97-04 | FRONT | Right | |
| 90762 | ACURA | TL 3.2L | 99-03 | FRONT | Right | |
| 90761 | ACURA | TL 3.2L | 99-04 | EXC TYPE S | FRONT | Left |
| 90781 | AUDI | TT | 99-05 | FRONT | Left | |
| 90782 | AUDI | TT | 99-05 | FRONT | Right | |
| 90691 | BUICK | LE SABRE | 00-04 | 16 IN WHEELS w/ 12 IN Fr. ROTORS | FRONT | Left |
| 90692 | BUICK | LE SABRE | 00-04 | 16 IN WHEELS w/ 12 IN Fr. ROTORS | FRONT | Right |
| 90691 | BUICK | PARK AVENUE, ULTRA | 97-04 | FRONT | Left | |
| 90692 | BUICK | PARK AVENUE, ULTRA | 97-04 | FRONT | Right | |
| 90691 | BUICK | RIVIERA | 97-99 | FRONT | Left | |
| 90692 | BUICK | RIVIERA | 97-99 | FRONT | Right | |
| 90691 | CADILLAC | DEVILLE, DHS, DTS | 00-02 | Exc. HD | FRONT | Left |
| 90692 | CADILLAC | DEVILLE, DHS, DTS | 00-02 | Exc. HD | FRONT | Right |
| 90691 | CADILLAC | DEVILLE, DHS, DTS | 03-05 | FRONT | Left | |
| 90692 | CADILLAC | DEVILLE, DHS, DTS | 03-05 | FRONT | Right | |
| 90691 | CADILLAC | ELDORADO | 97-02 | FRONT | Left | |
| 90691 | CADILLAC | SEVILLE, STS, SLS | 97-02 | FRONT | Left | |
| 90692 | CADILLAC | ELDORADO | 97-02 | FRONT | Right | |
| 90692 | CADILLAC | SEVILLE, STS, SLS | 97-02 | FRONT | Right | |
| 90691 | CHEVROLET | IMPALA | 00-04 | Police & HD | FRONT | Left |
| 90691 | CHEVROLET | MONTE CARLO | 00-04 | FRONT | Left | |
| 90692 | CHEVROLET | IMPALA | 00-04 | Police & HD | FRONT | Right |
| 90692 | CHEVROLET | MONTE CARLO | 00-04 | FRONT | Right | |
| 90461 | CHEVROLET | CORVETTE | 88-96 | REAR | Left | |
| 90462 | CHEVROLET | CORVETTE | 88-96 | REAR | Right | |
| 90681 | CHEVROLET | CAMARO | 93-97 | FRONT | Left | |
| 90682 | CHEVROLET | CAMARO | 93-97 | FRONT | Right | |
| 90691 | CHEVROLET | CAMARO | 98-02 | FRONT | Left | |
| 90692 | CHEVROLET | CAMARO | 98-02 | FRONT | Right | |
| 90861 | DODGE | VIPER | 92-02 | FRONT | Left | |
| 90871 | DODGE | VIPER | 92-02 | REAR | Left | |
| 90862 | DODGE | VIPER | 92-02 | FRONT | Right | |
| 90872 | DODGE | VIPER | 92-02 | REAR | Right | |
| 90601 | FORD | CROWN VICTORIA | 03-04 | FRONT | Left | |
| 90602 | FORD | CROWN VICTORIA | 03-04 | FRONT | Right | |
| 93071 | FORD | MUSTANG | 94-03 | FRONT | Left | |
| 93091 | FORD | MUSTANG COBRA | 94-03 | FRONT | Left | |
| 93072 | FORD | MUSTANG | 94-03 | FRONT | Right | |
| 93092 | FORD | MUSTANG COBRA | 94-03 | FRONT | Right | |
| 90762 | HONDA | ACCORD COUPE | 03-04 | V6 6SPD | FRONT | Right |
| 90761 | HONDA | ACCORD COUPE | 03-05 | V6 6SPD | FRONT | Left |
| 90762 | HONDA | ODYSSEY | 99-03 | FRONT | Right | |
| 90761 | HONDA | ODYSSEY | 99-04 | FRONT | Left | |
| 90351 | INFINITI | G35 | 03-04 | TOURING | FRONT | Left |
| 90371 | INFINITI | G35 | 03-04 | TRACK | FRONT | Left |
| 90352 | INFINITI | G35 | 03-04 | TOURING | FRONT | Right |
| 90372 | INFINITI | G35 | 03-04 | TRACK | FRONT | Right |
| 90151 | MAZDA | RX 8 | 2004 | SPORT | FRONT | Left |
| 90191 | MAZDA | RX 8 | 2004 | NON SPORT | FRONT | Left |
| 90152 | MAZDA | RX 8 | 2004 | SPORT | FRONT | Right |
| 90192 | MAZDA | RX 8 | 2004 | NON SPORT | FRONT | Right |
| 90411 | MAZDA | RX 7 | 93-95 | FRONT | Left | |
| 90412 | MAZDA | RX 7 | 93-95 | FRONT | Right | |
| 90601 | MERCURY | MARAUDER | 03-04 | FRONT | Left | |
| 90602 | MERCURY | MARAUDER | 03-04 | FRONT | Right | |
| 90831 | MITSUBISHI | LANCER EVOLUTION | 03-04 | FRONT | Left | |
| 90841 | MITSUBISHI | LANCER EVOLUTION | 03-04 | REAR | Left | |
| 90832 | MITSUBISHI | LANCER EVOLUTION | 03-04 | FRONT | Right | |
| 90842 | MITSUBISHI | LANCER EVOLUTION | 03-04 | REAR | Right | |
| 90351 | NISSAN | 350Z | 03-04 | TOURING | FRONT | Left |
| 90371 | NISSAN | 350Z | 03-04 | TRACK | FRONT | Left |
| 90352 | NISSAN | 350Z | 03-04 | TOURING | FRONT | Right |
| 90372 | NISSAN | 350Z | 03-04 | TRACK | FRONT | Right |
| 90691 | OLDSMOBILE | INTRIGUE | 1998 | HEAVY DUTY | FRONT | Left |
| 90692 | OLDSMOBILE | INTRIGUE | 1998 | HEAVY DUTY | FRONT | Right |
| 90691 | OLDSMOBILE | AURORA | 97-03 | FRONT | Left | |
| 90692 | OLDSMOBILE | AURORA | 97-03 | FRONT | Right | |
| 90691 | PONTIAC | BONNEVILLE, EXECUTIVE | 00-04 | SLE, SSEI | FRONT | Left |
| 90692 | PONTIAC | BONNEVILLE, EXECUTIVE | 00-04 | SLE, SSEI | FRONT | Right |
| 90681 | PONTIAC | FIREBIRD | 93-97 | FRONT | Left | |
| 90682 | PONTIAC | FIREBIRD | 93-97 | FRONT | Right | |
| 90691 | PONTIAC | FIREBIRD, FORMULA, TRANS AM | 98-02 | FRONT | Left | |
| 90692 | PONTIAC | FIREBIRD, FORMULA, TRANS AM | 98-02 | FRONT | Right | |
| 90661 | SUBARU | WRX STI | 04-05 | FRONT | Left | |
| 90662 | SUBARU | WRX STI | 04-05 | FRONT | Right | |
| 90781 | VW | GOLF GTI | 02-03 | 337 ED.,20th Anniv. | FRONT | Left |
| 90782 | VW | GOLF GTI | 02-03 | 337 ED.,20th Anniv. | FRONT | Right |
| 90781 | VW | JETTA | 03-04 | GLI | FRONT | Left |
| 90782 | VW | JETTA | 03-04 | GLI | FRONT | Right |
