Quick view sku: PD1001-3R7 [PD1001-3R7] RB (XR70) Track Pad: Mitsubishi EVO, Camaro SS, CTS-V, Tesla Model S Front MSRP: $300.00 Was: Now: $285.25 Add to Cart Compare Quick view sku: PD1001-391 [PD1001/PD1165-391] RB (XT910) Street Pad: Mitsubishi EVO, Camaro SS, CTS-V, Tesla Model S, Corvette C8 Stingray Front MSRP: $250.00 Was: Now: $237.50 Add to Cart Compare Quick view sku: PD1368-391 [PD1368-391] RB XT910 Brake Pad: EVO X & RB 2 Pot Rear Caliper MSRP: $150.70 Was: Now: $143.17 Add to Cart Compare Quick view sku: PD1368-39 [PD1368-39] RB ET900 Brake Pad: EVO X & RB 2 Pot Rear Caliper MSRP: $184.80 Was: Now: $175.56 Add to Cart Compare Quick view sku: SP02 EVO 8-9 14mm Wheel Spacer MSRP: $53.90 Was: Now: $51.21 Add to Cart Compare Quick view sku: EVO-43 EVO 8/9/10 M12x1.5 Wheel Stud for Stock Replacement (10 pc. - Axle Set) MSRP: $79.20 Was: Now: $75.24 Add to Cart Compare Quick view sku: EVO8.9-IRP RB 6/4 Pot Caliper Kit (380/332) for Mistubishi EVO 8/9 (P/N 2485-K & 2034-K) MSRP: $5,950.00 Was: Now: $5,650.00 Choose Options Compare Quick view sku: 1305-03-311 Rotor Rings (320x32) for EVO 8-9 FRONT (Price is for pair) MSRP: $825.00 Was: Now: $783.75 Add to Cart Compare Quick view sku: MIT-IRK-320.300 Save 10% on RB 2pc Rotor Bundle Kit (320/300) for EVO 8-9 (P/N 2216 & 2043) MSRP: $2,095.00 Was: Now: $1,990.00 Choose Options Compare Quick view [PD1001-3R7] RB (XR70) Track Pad: Mitsubishi EVO, Camaro SS, CTS-V, Tesla Model S Front RB Brake Pad Selection Guide MSRP: $300.00 Was: Now: $285.25 Add to Cart Compare Quick view [PD1001/PD1165-391] RB (XT910) Street Pad: Mitsubishi EVO, Camaro SS, CTS-V, Tesla Model S, Corvette C8 Stingray Front RB Brake Pad Selection Guide MSRP: $250.00 Was: Now: $237.50 Add to Cart Compare Quick view [PD1368-391] RB XT910 Brake Pad: EVO X & RB 2 Pot Rear Caliper RB Brake Pad Selection Guide MSRP: $150.70 Was: Now: $143.17 Add to Cart Compare Quick view [PD1368-39] RB ET900 Brake Pad: EVO X & RB 2 Pot Rear Caliper RB Brake Pad Selection Guide MSRP: $184.80 Was: Now: $175.56 Add to Cart Compare Quick view EVO 8-9 14mm Wheel Spacer 14mm spacer, EDP coated for EVO. MSRP: $53.90 Was: Now: $51.21 Add to Cart Compare Quick view EVO 8/9/10 M12x1.5 Wheel Stud for Stock Replacement (10 pc. - Axle Set) RacingBrake wheels studs are made of alloy steel, heat treated, and certified to SAE 10.9 class. Length: 43mm / 1.70"Proof Load: 830 MPa (120,000 psi)Tensile Strength: 1,040 MPa (151,000 psi) MSRP: $79.20 Was: Now: $75.24 Add to Cart Compare Quick view RB 6/4 Pot Caliper Kit (380/332) for Mistubishi EVO 8/9 (P/N 2485-K & 2034-K) Kit includes: 2 ea front 6 pot calipers 2 ea front 2 pc rotors 2 ea front caliper adaptors 2 ea rear 4 pot calipers 2 ea rear 2 pc rotors 2 ea rear caliper adaptors 1 car set brake pads Replacement rotor rings: Front: D501-04 Rear:... MSRP: $5,950.00 Was: Now: $5,650.00 Choose Options Compare Quick view Rotor Rings (320x32) for EVO 8-9 FRONT (Price is for pair) Rotor Material: Racing Formula Alloyed Gray Iron & Heat treated. This rotor ring is a replacement for EVO 8/9 fits OE hats MSRP: $825.00 Was: Now: $783.75 Add to Cart Compare Quick view Save 10% on RB 2pc Rotor Bundle Kit (320/300) for EVO 8-9 (P/N 2216 & 2043) **Modification required for rear fitment. (See below) Disc finishes: Front rotors in this kit are "surface-mount" design w/Straight slots. Rear rotors are "center-mount" design (Drills+slots or Open slots). Replacement brake pads: Front:PD1001 Rear:... MSRP: $2,095.00 Was: Now: $1,990.00 Choose Options Compare Compare Selected × OK
