Quick view Corvette 6/4 Pot Caliper Brake Kit (390/380) for Corvette C5/C6 Upgrade to C6 CCM Rotor Size (P/N 2242-K & 2243-K) MSRP: $8,200.00 Was: Now: $7,790.00 Choose Options Compare Quick view Corvette Z06 (PZ-41) Pad EZ Bolt Rear Axle Set (12 pcs) Available on Amazon MSRP: $155.10 Was: Now: $147.35 Add to Cart Compare Quick view Corvette Z06 (PZ-41) Rear 4 Pot Caliper Brake Pad EZ Bolt ( 2 pcs/pack ) MSRP: $26.50 Was: Now: $25.20 Add to Cart Compare Quick view Corvette Z06 (PZ-61) Pad EZ Bolt Front Axle Set (16 pcs ) Available on Amazon MSRP: $206.80 Was: Now: $196.46 Add to Cart Compare Quick view Corvette Z06 (PZ-61) Front 6 Pot Caliper Brake Pad EZ Bolts ( 2 pcs/pack ) MSRP: $26.50 Was: Now: $25.20 Add to Cart Compare Quick view RB 2Pc Rotor Kit (340x32/330x24) for C6 Corvette Z51 (05-09) Front & Rear (P/N 2068 & 2069) MSRP: $1,870.00 Was: Now: $1,776.50 Add to Cart Compare SALE Quick view RB 2 Pc Rotor Kit (355x32/340x26) for C6 Corvette Z06 w/PBR 6/4 Pot Caliper (P/N 2072 & 2073) - Disc Finish: Drills & Slots MSRP: $2,700.00 Was: $2,565.00 Now: $2,209.50 Choose Options Compare Quick view RB 2Pc Rotor Kit (390x36/380x32) for Corvette C6 ZR1 / Z06 Carbon Edition w/CCM Rotors Conversion to Iron Rotos Front & Rear (P/N 2242 & 2243) MSRP: $3,145.00 Was: Now: $2,988.00 Choose Options Compare SALE Quick view RB 2pc Rotors Surface-mt (355x32mm) for C6 Corvette Z06 & Grand Sport 2006-13 Front MSRP: $1,150.00 Was: $1,092.50 Now: $992.75 Choose Options Compare Quick view Corvette 6/4 Pot Caliper Brake Kit (390/380) for Corvette C5/C6 Upgrade to C6 CCM Rotor Size (P/N 2242-K & 2243-K) Kit includes: 2 ea 6 pot Corvette C6 ZR1 front calipers 2 ea Front lightweight 2 pc rotors (390x36mm) 2 ea 4 pot Corvette C6 ZR1 rear calipers 2 ea Rear lightweight 2 pc rotors (380x32mm) 1 car set street brake pads Replacement brake... MSRP: $8,200.00 Was: Now: $7,790.00 Choose Options Compare Quick view Corvette Z06 (PZ-41) Pad EZ Bolt Rear Axle Set (12 pcs) Available on Amazon Click here: This brake pad EZ bolt is designed and made exclusively by RacingBrake to replace the bolts that come with the original caliper and tend to bind to the caliper and break.RB EZ bolts are made of high strength alloyed steel and heat-treated. MSRP: $155.10 Was: Now: $147.35 Add to Cart Compare Quick view Corvette Z06 (PZ-41) Rear 4 Pot Caliper Brake Pad EZ Bolt ( 2 pcs/pack ) This brake pad EZ bolt is designed and made exclusively by RacingBrake to replace the bolts that come with the original caliper and tend to bind to the caliper and break.RB EZ bolts are made of high strength alloyed steel and heat-treated. Qty: 2... MSRP: $26.50 Was: Now: $25.20 Add to Cart Compare Quick view Corvette Z06 (PZ-61) Pad EZ Bolt Front Axle Set (16 pcs ) Available on Amazon Click here: This brake pad EZ bolt is designed and made exclusively by RacingBrake to replace the bolts that come with the original caliper and tend to bind to the caliper and break.RB EZ bolts are made of high strength alloyed steel and heat-treated... MSRP: $206.80 Was: Now: $196.46 Add to Cart Compare Quick view Corvette Z06 (PZ-61) Front 6 Pot Caliper Brake Pad EZ Bolts ( 2 pcs/pack ) This brake pad EZ bolt is designed and made exclusively by RacingBrake to replace the bolts that come with the original caliper and tend to bind to the caliper and break.RB EZ bolts are made of high strength alloyed steel and heat-treated. Qty: 2... MSRP: $26.50 Was: Now: $25.20 Add to Cart Compare Quick view RB 2Pc Rotor Kit (340x32/330x24) for C6 Corvette Z51 (05-09) Front & Rear (P/N 2068 & 2069) MSRP: $1,870.00 Was: Now: $1,776.50 Add to Cart Compare SALE Quick view RB 2 Pc Rotor Kit (355x32/340x26) for C6 Corvette Z06 w/PBR 6/4 Pot Caliper (P/N 2072 & 2073) - Disc Finish: Drills & Slots Replacement rotor rings: Front: D402-01-351 Rear: D308-04-351 Replacement brake pads: Front pads: PD1185F Rear pads: PD1185R Installation Notes: Rear rotor installation requires trimming the lip of backing plate to avoid interference w/two piece... MSRP: $2,700.00 Was: $2,565.00 Now: $2,209.50 Choose Options Compare Quick view RB 2Pc Rotor Kit (390x36/380x32) for Corvette C6 ZR1 / Z06 Carbon Edition w/CCM Rotors Conversion to Iron Rotos Front & Rear (P/N 2242 & 2243) Kit Contents: 2 ea Front 2pc rotors (390x36 vs. 394x36mm). Our rotors fits better than OE 394mm that eliminate the undesirable rusty lips. 2 ea Rear e pc rotors (380x32 vs. 380x34mm) 1 set brake pads made for iron rotors - Optional Feature &... MSRP: $3,145.00 Was: Now: $2,988.00 Choose Options Compare SALE Quick view RB 2pc Rotors Surface-mt (355x32mm) for C6 Corvette Z06 & Grand Sport 2006-13 Front Kit includes: 2 ea. surface mount 2-PC rotors (Slotted) 1 set RB front street performance brake pads - Optional. Rotor weight: 18.7 lbs/ea Replacement rotor rings: 1406-03 Replacement brake pads: PD1185F-35 MSRP: $1,150.00 Was: $1,092.50 Now: $992.75 Choose Options Compare 1 2 Next 1 2 Next Compare Selected × OK
