Shop by Brand
CORVETTE
Application/Sub-model Year Front Rear
C6 Z06
Rotor options
05-13
PZ-61 (33/33/33x32)
Piston area: 51.32 cm^2
PZ-41 (30/30x35)
Piston area: 28.27
C6 ZR1
Rotor options
05-13
BZ-61 (30/34/38x32)
Piston area: 54.98
172-2515/2516
BZ-41 (30/34x30)
Piston area: 32.3
172-2517/2518
C7 Z06 w/Z07 Pkg.
CCM Rotors (394/390mm)
GM-CRK-04
Conversion kit:
GM-IRK-09
14-19
BZ-62 (30/34/38x32)=BZ-61
Piston area: 54.98
172-2489/2490
BZ-41 (30/34x30)
Piston area: 32.3
172-2491/2492
C7 Z06
Iron Rotors (370/365mm)
GM-IRK-07
14-19
BC-61 (30/34/38x30) = (Camaro G5 ZL1)
Piston area: 54.98
C7-42 (30/30x27.5)*
Piston area: 28.27
C7 (Std & Z51)
Iron Rotors (340/338mm)
GM-IRK-06
14-19
C7-41 (42/42x27.5)*
Piston area: 55.42
C7-42 (30/30x27.5)*
Piston area: 28.27
C8 Z06 (Iron Rotors)
2023+
Piston area: 54.98
BZ-43 (36/40x30)
Piston area: 45.49
C8 Z06 w/Z07 (CCB) Pkg.
2023+
BZ-63 (30/34/38x32)=BZ-61
Piston area: 54.98
BZ-43 (36/40x30)
Piston area: 45.49
C8 (Std & Z51)
Iron Rotors:Z51: C8-IRK-01
(Std) Stingray: C8-IRK-02
2020+
C8-41 (42/42x27.5) (=C7-41)
Piston area: 55.42
C8-42 (38/38x27.5) (= BF42)
Piston area: 45.36
*These dust boots & pistons are different from conventional Internal Fit type (only oil seals are compatible), so they are not COMPATIBLE with older models.
GC7 Z51 calipers not only the boots and pistons are different, they don't come with cross-over tubes because their pistons are same size unlike BC-42, with differential bores so no orientation concern, however there is a small part that holds brake fluid from leaking out of caliper halves after assembly. See pic below.
Instead of OE's bushing, we use O-ring which is compatible with OE bushing based on our hydro test and is a better alternative in material and design.
O-Ring can be purchase here:
https://racingbrake.com/or-09
O-Ring (Left) is easier to handle than OE bushing (Right)
Where the O-Ring fits (Outboard half)
