Quick view 2 ea. RB Light Wt Rotor Hat for Corvette C6 ZR1 Rear CCM Rotors (380mm) (Incl. hardware kit) MSRP: $1,936.00 Was: Now: $1,839.20 Add to Cart Compare Quick view [PD-ZR1-360] Brake Pads for CCM Rotors - Corvette ZR1, Camaro Z28, Viper ACRE, Ferrari F458/California & 488, Alfa Rome, Nissan GT-R (w/RB rotors) & RB 6/4 Caliper Kit - FRONT & REAR: (PD1395 & PD1165) MSRP: Was: Now: $1,050.00 Choose Options Compare Quick view GM/Brembo CCB Brake System Kit (394/380) for Corvette C6 05-13 (PN: 2C01 & 2C02) MSRP: $14,500.00 Was: Now: $13,800.00 Choose Options Compare Quick view RB 2Pc Rotor Kit (390x36/380x32) for Corvette C6 ZR1 / Z06 Carbon Edition w/CCM Rotors Conversion to Iron Rotos Front & Rear (P/N 2242 & 2243) MSRP: $3,145.00 Was: Now: $2,988.00 Choose Options Compare Quick view RB-CCB Rotor Kit (394/380) for Corvette C6 (P/N 2C01 & 2C02) MSRP: $12,200.00 Was: Now: $10,500.00 Choose Options Compare Quick view RB-CCB System Kit (394/380) for Corvette C6 (P/N 2C01-K & 2C02-K) MSRP: $16,632.62 Was: Now: $15,800.99 Choose Options Compare Quick view 2 ea. RB Light Wt Rotor Hat for Corvette C6 ZR1 Rear CCM Rotors (380mm) (Incl. hardware kit) 2 - Light weight composite hats (OE Emergency/Parking brake compatible) 20 - M6 self-locking nuts 20 - I Block (IB-30) 20 - M6x1 bolts 20 - Springs Weight comparison: OE Stainless Steel Hat: RB Composite Hat (Aluminum hat w/iron liner): MSRP: $1,936.00 Was: Now: $1,839.20 Add to Cart Compare Quick view [PD-ZR1-360] Brake Pads for CCM Rotors - Corvette ZR1, Camaro Z28, Viper ACRE, Ferrari F458/California & 488, Alfa Rome, Nissan GT-R (w/RB rotors) & RB 6/4 Caliper Kit - FRONT & REAR: (PD1395 & PD1165) Installation Note: For Ford GT350 6 pot calipers installation it requires a hardware kit (included on request) to create proper tension from the hold down spring to the brake pads to avoid rattling. Brembo OE ZR1 brake pad dimension flow as seen on... MSRP: Was: Now: $1,050.00 Choose Options Compare Quick view GM/Brembo CCB Brake System Kit (394/380) for Corvette C6 05-13 (PN: 2C01 & 2C02) Kit includes: 2 ea. Front GM 6-piston calipers 2 ea. Rear GM 4-piston calipers 2 ea. Front GM CCM rotors (394x36mm) 2 ea. Rear GM CCM rotors (380x34mm) 1 car set brake pads (Optional) 1 car set brake lines (Optional) Feature &... MSRP: $14,500.00 Was: Now: $13,800.00 Choose Options Compare Quick view RB 2Pc Rotor Kit (390x36/380x32) for Corvette C6 ZR1 / Z06 Carbon Edition w/CCM Rotors Conversion to Iron Rotos Front & Rear (P/N 2242 & 2243) Kit Contents: 2 ea Front 2pc rotors (390x36 vs. 394x36mm). Our rotors fits better than OE 394mm that eliminate the undesirable rusty lips. 2 ea Rear e pc rotors (380x32 vs. 380x34mm) 1 set brake pads made for iron rotors - Optional Feature &... MSRP: $3,145.00 Was: Now: $2,988.00 Choose Options Compare Quick view RB-CCB Rotor Kit (394/380) for Corvette C6 (P/N 2C01 & 2C02) Discs are made with continuous (long) carbon fibers (vs. OE chopped fibers) for higher strength and durability. Click below to learn more about the material and design: https://racingbrake.com/tech-info/ The rotor kit is bundled with our... MSRP: $12,200.00 Was: Now: $10,500.00 Choose Options Compare Quick view RB-CCB System Kit (394/380) for Corvette C6 (P/N 2C01-K & 2C02-K) Kit includes: 2 ea. RB 6-piston caliper 2 ea. Front CCM rotor (394x36mm) 2 ea. RB 4-piston caliper 2 ea. Rear CCM rotor (380x34mm) 1 car set Caliper adaptors 1 car set Stainless steel braided brake lines (optional) 1 car set street ccb pads... MSRP: $16,632.62 Was: Now: $15,800.99 Choose Options Compare Compare Selected × OK
