Quick view RB 2 pc Rotor Kit (300X24) for Porsche Boxster, 993 Base (CS) Rear - See Installation Note Under Description for the Required Modification before Ordering. MSRP: $1,350.00 Was: Now: $1,285.50 Pre-Order Now Compare Quick view RB 2 Pc Rotors - Porsche 987 Boxster-S / Cayman-S / 996 C2 / C4 Front MSRP: $998.00 Was: Now: $948.00 Add to Cart Compare Quick view RB Brake Lines Porsche Cayman/Boxster 981/982 Base/S/GTS - 4 lines front & rear kit MSRP: $120.00 Was: Now: $102.00 Add to Cart Compare Quick view RB Caliper Spacer Kit for Porsche 996 CS, Cayman/Boxster (96-12) Front & Rear Upgrade to 330/330mm (from 318/299mm) MSRP: $430.00 Was: Now: $408.50 Choose Options Compare Quick view RB Pad Pins for Porsche, Tesla Plaid Brembo Calipers (Pack of 4) MSRP: $165.00 Was: Now: $156.75 Choose Options Compare Quick view RB 2 pc Rotor Kit (300X24) for Porsche Boxster, 993 Base (CS) Rear - See Installation Note Under Description for the Required Modification before Ordering. Installation notes: This rotor although is made for a direct replacement to stock, but in order to accommodate the OE parking brake drum with 180mm dia, the brake pads bottom needs to trim to about 40mm depth to avoid overhang. Kit includes: 2 ea 2 pc... MSRP: $1,350.00 Was: Now: $1,285.50 Pre-Order Now Compare Quick view RB 2 Pc Rotors - Porsche 987 Boxster-S / Cayman-S / 996 C2 / C4 Front This rotor fits the following models front: Boxster S 00-10 996/997 Carrera 2 98-08 996/997 Carrera 4 99-08 Cayman S 06-08 Estd wt: 13.8 lbs per rotor OEM# 996-351-405-02-M5 MSRP: $998.00 Was: Now: $948.00 Add to Cart Compare Quick view RB Brake Lines Porsche Cayman/Boxster 981/982 Base/S/GTS - 4 lines front & rear kit Only front brake lines are included in this kit. These lines are built to RB specifications, meeting D.O.T. Certification. Stainless steel brake lines improve braking performance, eliminates the spongy feel of rubber hoses and provides superior brake... MSRP: $120.00 Was: Now: $102.00 Add to Cart Compare Quick view RB Caliper Spacer Kit for Porsche 996 CS, Cayman/Boxster (96-12) Front & Rear Upgrade to 330/330mm (from 318/299mm) Kit includes: 2 ea front caliper spacers for 330 rotors (upgrade from 318mm) 2 ea rear caliper spacers for 330mm rotors (Upgrade from 299mm) 8 ea M12x1.5 alloyed steel longer bolts for BBK Feature & benefit: Instant BBK while stay in OE... MSRP: $430.00 Was: Now: $408.50 Choose Options Compare Quick view RB Pad Pins for Porsche, Tesla Plaid Brembo Calipers (Pack of 4) Kit contents: 4 sets Pins & screws 4 ea Pins only (optional) 4 ea Screws only (optional) (12 points vs. OE 10 points) Materials/specs: Pins - Stainless steel. Screw - Grade 9, black oxidized - Compatibility is certified by RB. Head: 12 points... MSRP: $165.00 Was: Now: $156.75 Choose Options Compare Compare Selected × OK
