Quick view RB 2 pc Rotor Kit (300X24) for Porsche Boxster, 993 Base (CS) Rear - See Installation Note Under Description for the Required Modification before Ordering. MSRP: $1,350.00 Was: Now: $1,285.50 Choose Options Compare Quick view RB 2 Pc Rotors - Porsche 987 Boxster-S / Cayman-S / 996 C2 / C4 Front MSRP: $998.00 Was: Now: $948.00 Add to Cart Compare Quick view RB Caliper Spacer Kit for Porsche 996 CS, Cayman/Boxster (96-12) Front & Rear Upgrade to 330/330mm (from 318/299mm) MSRP: $430.00 Was: Now: $408.50 Choose Options Compare Quick view RB 2 pc Rotor Kit (300X24) for Porsche Boxster, 993 Base (CS) Rear - See Installation Note Under Description for the Required Modification before Ordering. Installation notes: This rotor although is made for a direct replacement to stock, but in order to accommodate the OE parking brake drum with 180mm dia, the brake pads bottom needs to trim to about... MSRP: $1,350.00 Was: Now: $1,285.50 Choose Options Compare Quick view RB 2 Pc Rotors - Porsche 987 Boxster-S / Cayman-S / 996 C2 / C4 Front This rotor fits the following models front: Boxster S 00-10 996/997 Carrera 2 98-08 996/997 Carrera 4 99-08 Cayman S 06-08 Estd wt: 13.8 lbs per rotor OEM# 996-351-405-02-M5 Â MSRP: $998.00 Was: Now: $948.00 Add to Cart Compare Quick view RB Caliper Spacer Kit for Porsche 996 CS, Cayman/Boxster (96-12) Front & Rear Upgrade to 330/330mm (from 318/299mm) Kit includes: 2 ea front caliper spacers for 330 rotors (upgrade from 318mm) 2 ea rear caliper spacers for 330mm rotors (Upgrade from 299mm) 8 ea M12x1.5 alloyed steel longer bolts for BBK Feature... MSRP: $430.00 Was: Now: $408.50 Choose Options Compare Compare Selected × OK
