Kit contents:
- 1 set (2 ea) 4-pot fixed piston caliper.
- 1 set (2 ea) actuator (assembled w/caliper) for parking brake (fully comptible w/OE e-motor).
- 1 set (2 ea) caliper adaptors.
- 1 set ccb brake pads ($427.50 value).
Feature & benefits:
- Easy installation - Simply swap e-motor from OE to RB caliper.
- Functionality and intergtity of OE calipers are fully retained.
- Improve the braking performance.
- Maintain even brake pad wear due to the fixed pistons for instant & even response from both sides vs. OE signle piston with a "push then pull" action.
- Use only one set of brake pad vs. 2 sets on those with a separate parking brake.
- Easy and low maintenance vs. OE 1 caliper or 2nd parking calipers set up.
- Rear: PDS4E1-360
Rear wheel fitment template: 2R10
OE Rear - 1-Piston caliper w/ePB:
RB - 4 piston caliper w/integrated ePB
