Quick view RB 2 Pc Rotor Kit (380/380) for Porsche 991 GT3 & 981 Cayman GT4 (Stock Replacement) PN: 2421/2422 MSRP: $3,840.00 Was: Now: $3,648.00 Choose Options Compare Quick view RB 2pc Rotors (380/380) OE Caliper BBK for Porsche 991 C2S/C4S Front & Rear (P/N: 2507-K & 2508-K) MSRP: $4,200.00 Was: Now: $3,990.00 Choose Options Compare Quick view RB Brake System Kit (380x34/380x30) Direct Replacement for Porsche 991 GT3, 981 GT4 MSRP: $9,000.00 Was: Now: $8,550.00 Choose Options Compare Quick view RB Brake System Kit (390x34/390x30) for Porsche 991 GT3 (Choose Option for Your Wheel Hub) MSRP: $7,660.00 Was: Now: $7,277.00 Choose Options Compare Quick view RB Upgrade Rotor Kit (from Iron 380/380 to PCCB Rotor Size 410/390mm) for 991 Turbo & 981 Cayman GT4 w/Std Iron Brakes (P/N 2307 & 2501) MSRP: $4,469.30 Was: Now: $4,245.84 Compare Quick view RB 2 Pc Rotor Kit (380/380) for Porsche 991 GT3 & 981 Cayman GT4 (Stock Replacement) PN: 2421/2422 Replacement brake pads: Front: PD1773 Rear: PD1740 Replacement rotor rings: Front: D501-04 Rear: D501-07 MSRP: $3,840.00 Was: Now: $3,648.00 Choose Options Compare Quick view RB 2pc Rotors (380/380) OE Caliper BBK for Porsche 991 C2S/C4S Front & Rear (P/N: 2507-K & 2508-K) This BBK is specially designed and packaged for upgrading your original 340/330mm (or 350/330mm) to the same rotor sizes as 991/992 GT3 380/380mm. Easy 100% bolt on installation. No bleeding to your brake system - Save trouble in bleeding the system if... MSRP: $4,200.00 Was: Now: $3,990.00 Choose Options Compare Quick view RB Brake System Kit (380x34/380x30) Direct Replacement for Porsche 991 GT3, 981 GT4 This brake kit is developed specifically to replace the OE brake kit that comes with standard brake (Red calipers & Iron rotors) or with pccb to downsize to 380 rotor kit to run smaller wheels & tires. Kit includes: 2 ea front track duty... MSRP: $9,000.00 Was: Now: $8,550.00 Choose Options Compare Quick view RB Brake System Kit (390x34/390x30) for Porsche 991 GT3 (Choose Option for Your Wheel Hub) Replacement brake pads: Front: PD1395 Rear: PD1165 Replacement rotor rings: Front D601-02 Rear: D601-06 MSRP: $7,660.00 Was: Now: $7,277.00 Choose Options Compare Quick view RB Upgrade Rotor Kit (from Iron 380/380 to PCCB Rotor Size 410/390mm) for 991 Turbo & 981 Cayman GT4 w/Std Iron Brakes (P/N 2307 & 2501) This rotor kit is made for upgrading from standard iron rotor (380/380) to pccb size (410/390) Kit includes: 2 ea. front RB light weight two piece rotors 2 ea. rear RB light weight two piece rotors (retains OE's emergency brake) 4 ea... MSRP: $4,469.30 Was: Now: $4,245.84 Compare Compare Selected × OK
