Quick view [PD-ZR1-360] Brake Pads for CCM Rotors - Corvette ZR1, Camaro Z28, Viper ACRE, Ferrari F458/California & 488, Alfa Rome, Nissan GT-R (w/RB rotors) & RB 6/4 Caliper Kit - FRONT & REAR: (PD1395 & PD1165) MSRP: Was: Now: $1,050.00 Choose Options Compare Quick view [PD-ZR1-397] RB (XT970) Track Pads for Iron Rotor Conversion from CCB - Corvette ZR1, Camaro Z28, Ferrari F458, McLaren etc. FRONT & REAR: (PD1395/PD1165) MSRP: $690.00 Was: Now: $655.50 Choose Options Compare Quick view RB 2pc Rotor Kit (394/360) for Ferrari F458/488/599 CCM to Iron Conversion (P/N 2454 & 2455) MSRP: $4,600.00 Was: Now: $4,370.00 Choose Options Compare Quick view RB-CCB Rotor Kit (394/360) for Ferrari F458/488/599/LaFerrari Stock CCB Rotors Replacement Front & Rear (P/N 2C57 & 2C48) MSRP: $15,600.00 Was: Now: $14,820.00 Choose Options Compare Quick view [PD-ZR1-360] Brake Pads for CCM Rotors - Corvette ZR1, Camaro Z28, Viper ACRE, Ferrari F458/California & 488, Alfa Rome, Nissan GT-R (w/RB rotors) & RB 6/4 Caliper Kit - FRONT & REAR: (PD1395 & PD1165) Installation Note: For Ford GT350 6 pot calipers installation it requires a hardware kit (included on request) to create proper tension from the hold down spring to the brake pads to avoid rattling. Brembo OE ZR1 brake pad dimension flow as seen on... MSRP: Was: Now: $1,050.00 Choose Options Compare Quick view [PD-ZR1-397] RB (XT970) Track Pads for Iron Rotor Conversion from CCB - Corvette ZR1, Camaro Z28, Ferrari F458, McLaren etc. FRONT & REAR: (PD1395/PD1165) This brake pad set is made with RB XT970 compound for iron rotors that are duly converted from factory CCM rotors. If you have original CCB rotors and looking for brake pad replacement you should order our ST600 compounds MSRP: $690.00 Was: Now: $655.50 Choose Options Compare Quick view RB 2pc Rotor Kit (394/360) for Ferrari F458/488/599 CCM to Iron Conversion (P/N 2454 & 2455) Kit includes: 2 ea front 2 pc iron rotor for CCB conversion (394x36) 2 ea rear 2 pc iron rotor for CCB conversion (360x32) 1 car set of brake pads Replacement disk: Front: D602-04 Rear: D501-10 Replacement brake pads: Front: PD1395 Rear:... MSRP: $4,600.00 Was: Now: $4,370.00 Choose Options Compare Quick view RB-CCB Rotor Kit (394/360) for Ferrari F458/488/599/LaFerrari Stock CCB Rotors Replacement Front & Rear (P/N 2C57 & 2C48) Kit includes: 2 ea front ccb rotors 394x36mm (Fits better than OE's 398x36mm) 2 ea rear ccb rotors 360x32mm(stock), or 390x32mm bbk* 2 ea rear caliper spacers & thin head bolts (If 390x32mm bbk is selected) 1 car set of CCB brake pads... MSRP: $15,600.00 Was: Now: $14,820.00 Choose Options Compare Compare Selected × OK
