Quick view RB 2pc Rotor Kit (360/330) for 2021+ Acura TLX; MDX 2022+ Type S w/ Brembo Caliper Stock Replacement Front & Rear; Also for Honda Ridgeline Upgrade (P/N 2688 & 2689) MSRP: $1,788.00 Was: Now: $1,699.00 Choose Options Compare Quick view RB Brake Pad for Acura MDX/PILOT 2022+ Rear Stock Replacement MSRP: $130.00 Was: Now: $118.60 Choose Options Compare Quick view RB Brake Pad for Acura TLX 2021+ ; 2022+ MDX Type S Front Stock Replacement MSRP: $220.00 Was: Now: $210.00 Choose Options Compare Quick view RB 2pc Rotor Kit (360/330) for 2021+ Acura TLX; MDX 2022+ Type S w/ Brembo Caliper Stock Replacement Front & Rear; Also for Honda Ridgeline Upgrade (P/N 2688 & 2689) Installatoion notes for Ridgeline owners: If you are a Ridgeline owners installing the front rotor kit would requires TLX Type S Brembo 4 pot calipers which are not included and are to be sourced by customer. Rear rotor kit is fully compatible with OE... MSRP: $1,788.00 Was: Now: $1,699.00 Choose Options Compare Quick view RB Brake Pad for Acura MDX/PILOT 2022+ Rear Stock Replacement MSRP: $130.00 Was: Now: $118.60 Choose Options Compare Quick view RB Brake Pad for Acura TLX 2021+ ; 2022+ MDX Type S Front Stock Replacement RB Pads length is made with a tighter tolerance (than OE pad) agasint OE calipers fitment, so our pads can fit tighter than OE pads w/o causing rocking movement inside the caliper as the car hits a bump which can cause rattling noise and vibration... MSRP: $220.00 Was: Now: $210.00 Choose Options Compare Compare Selected × OK
