Quick view RB 2pc Rotor Kit (360/330) for 2021+ Acura TLX; MDX 2022+ Type S w/ Brembo Caliper Stock Replacement Front & Rear (P/N 2688 & 2689) MSRP: $1,788.00 Was: Now: $1,699.00 Choose Options Compare Quick view RB 2pc Rotor Kit (360x32) for Ridgeline Retorfit to TLX Brembo Calipers Front (P/N 2715) MSRP: $910.00 Was: Now: $864.50 Pre-Order Now Compare Quick view RB Brake Pad for Acura TLX 2021+ ; 2022+ MDX Type S Front Stock Replacement MSRP: $220.00 Was: Now: $210.00 Choose Options Compare Quick view RB Brake Pad for Acura TLX 2021+ Type S Rear Stock Replacement MSRP: $130.00 Was: Now: $118.60 Choose Options Compare Quick view RB 2pc Rotor Kit (360/330) for 2021+ Acura TLX; MDX 2022+ Type S w/ Brembo Caliper Stock Replacement Front & Rear (P/N 2688 & 2689) General note: RB front rotors are 360mm (vs. OE 363mm) which fit pad better than OE so no rusty lip is developed like OE. RB rotors are made 2mm thicker than OE (both front & rear) for extra... MSRP: $1,788.00 Was: Now: $1,699.00 Choose Options Compare Quick view RB 2pc Rotor Kit (360x32) for Ridgeline Retorfit to TLX Brembo Calipers Front (P/N 2715) Feature & benefit: Big rotor kit is specially made for Ridgeline upgrade by swapping to TLX Brembo 4-pot calipers (Not included) Instant BBK 100% direct bolt on installation Requires no brackets or... MSRP: $910.00 Was: Now: $864.50 Pre-Order Now Compare Quick view RB Brake Pad for Acura TLX 2021+ ; 2022+ MDX Type S Front Stock Replacement RB Pads length is made with a tighter tolerance (than OE pad) agasint OE calipers fitment, so our pads can fit tighter than OE pads w/o causing rocking movement inside the caliper as the car hits a... MSRP: $220.00 Was: Now: $210.00 Choose Options Compare Quick view RB Brake Pad for Acura TLX 2021+ Type S Rear Stock Replacement   MSRP: $130.00 Was: Now: $118.60 Choose Options Compare Compare Selected × OK
