Quick view sku: 9081-111 RB 1pc rotor kit (290x10mm) w/170mm drum - Subaru Rear 09-13 MSRP: $271.70 Now: $258.12 Add to Cart Compare Quick view sku: 2312 RB 2 pc Rotor (294x24) for Scion FRS, Subaru BRZ & WRX (w/Dual Piston Caliper) Front MSRP: $867.90 Now: $824.51 Choose Options Compare Quick view sku: 2014-K RB BBK (322x25) for Subaru BRZ, Scion FR-S, GT86 Front MSRP: $2,035.00 Now: $1,933.25 Choose Options Compare Quick view sku: BRZ-IRP-01 Save 10% on RB BBK (332/330) Combo Kit for Subaru WRX (2008+)/BRZ; Toyota GT86; Scion FR-S Front & Rear (P/N 2567-K & 2315-K) MSRP: $4,200.00 Now: $3,990.00 Compare SALE Quick view sku: BRZ-IRP-02 Save 10% on RB BBK/OE Caliper kit (322/316) for Subaru BRZ, Scion FR-S, GT86 (2014-K & 2060-K) MSRP: $2,579.00 Was: $2,450.05 Now: $2,321.10 Choose Options Compare Quick view RB 1pc rotor kit (290x10mm) w/170mm drum - Subaru Rear 09-13 Material: Alloyed Gray IronMachining: Straight SlotSurface: EDP Coating w/cross cut grinding on friction surface Rotor wt: 10.7 lbs MSRP: $271.70 Now: $258.12 Add to Cart Compare Quick view RB 2 pc Rotor (294x24) for Scion FRS, Subaru BRZ & WRX (w/Dual Piston Caliper) Front Rotor Material: Racing Formula Alloyed Gray Iron & Heat treated Machining: Open Slot Surface: EDP Coating w/cross cut grinding on surface. Replacement components: Brake pads: PD647 Rotor rings: D200-03 MSRP: $867.90 Now: $824.51 Choose Options Compare Quick view RB BBK (322x25) for Subaru BRZ, Scion FR-S, GT86 Front Replacement components: brake pads: PD647 rotor rings: D214-01 rotor hats: H801-05 MSRP: $2,035.00 Now: $1,933.25 Choose Options Compare Quick view Save 10% on RB BBK (332/330) Combo Kit for Subaru WRX (2008+)/BRZ; Toyota GT86; Scion FR-S Front & Rear (P/N 2567-K & 2315-K) Kit Includes: 2 ea front 4 pot calipers 2 ea lightweight 2 pc rotors (332x26mm) 2 ea rear 2 pot calipers 2 ea lightweight 2 pc rotors (330x22mm built with drum brake 100% compatible with OE) 1 car set brake pads 1 set SS brake lines Replacement... MSRP: $4,200.00 Now: $3,990.00 Compare SALE Quick view Save 10% on RB BBK/OE Caliper kit (322/316) for Subaru BRZ, Scion FR-S, GT86 (2014-K & 2060-K) Replacement components Brake pads: Front: PD647 Rear: PD770 Front rotor rings: D214-01 Rear 1pc: 9160-141 MSRP: $2,579.00 Was: $2,450.05 Now: $2,321.10 Choose Options Compare Compare Selected × OK
