Note:
The dust boots selection in this section is for Internal Fit boots only, and IS NOT COMPATIBLE for calipers with External Fit dust boots on late model cars (See list below) or non Brembo calipers (such as Corvette Z06 made by PBR).
Dust boots listed in this section "Select by Piston Size" is good only for internal fit.
For example if your pistons has 38mm in diameter, then DB-38 is good for you, but if you have external fit boots you must add 3mm to the diameter i.e. DB-41 should be the one to order. In general even number is for internal fit, odd number is for external fit.
Dust boots for the following calipers have external fit boots so it's more assured to order from the car make to avoid ordering by mistake.
Ford Focus RS (front-38mm)
Corvette C7/C8 Z51 (front-42mm & rear-30mm)
Camaro G6 (front-42mm & rear-30mm)
Corvette Z06 (Calipers made by PBR)
Subaru STi (2018+) - Will soon be available
Front 6 pot: 30/34/38mm
Rear 2 pot: 40mm
