Quick view sku: 2214-K RB 1-Pc Rotor BBK (300x28) For Acura TL/TSX/RSX Front MSRP: $1,760.00 Now: $1,672.00 Choose Options Compare Quick view sku: 2151-K RB 1-Pc Rotor BBK (324x28) for Acura TL/TSX/RSX Front MSRP: $1,975.60 Now: $1,876.82 Add to Cart Compare Quick view sku: 90371A RB 1pc rotor (Slotted) - Acura TL/TSX/RSX BBK Replacement MSRP: $190.00 Now: $180.00 Add to Cart Compare Quick view sku: 2153-K RB 2 pc Rotors (325x12) for Acura TL Rear (w/Drum E-brake) BBK MSRP: $1,470.00 Now: $1,399.00 Add to Cart Compare Quick view sku: 2108 RB 2pc Rotors (310x25) - Acura TL Type S w/Brembo Caliper FRONT 04-08 MSRP: $876.00 Now: $832.20 Choose Options Compare Quick view sku: PD537-38 RB Brake Pad (ET800) for Honda Accord/S2000 00-08, Acura TSX 09+ REAR MSRP: $120.00 Now: $114.00 Choose Options Compare Quick view sku: 2067-K RB Stock Size (300x28mm) Brake Kit For Acura TL/TSX/RSX/MDX Front MSRP: $2,211.00 Now: $2,100.45 Choose Options Compare Quick view RB 1-Pc Rotor BBK (300x28) For Acura TL/TSX/RSX Front Kit includes: 2 ea RB 4 pot calipers 2 ea caliper adaptors 2 ea 1 pc rotors 1 seet brake pads Replacement rotors: 90761/2A Replacement brake pads: PD647-391 Weight comparison on calipers: RB 4 pot calipers (loaded) OE floating dual piston Cast... MSRP: $1,760.00 Now: $1,672.00 Choose Options Compare Quick view RB 1-Pc Rotor BBK (324x28) for Acura TL/TSX/RSX Front Kin includes: 2 ea RB 4 pot calipers 2 ea caliper adaptors 2 ea 1 pc rotors 1 seet brake pads Replacement rotors: 90371A Replacement brake pads: PD647-391 MSRP: $1,975.60 Now: $1,876.82 Add to Cart Compare Quick view RB 1pc rotor (Slotted) - Acura TL/TSX/RSX BBK Replacement MSRP: $190.00 Now: $180.00 Add to Cart Compare Quick view RB 2 pc Rotors (325x12) for Acura TL Rear (w/Drum E-brake) BBK This kit is based off of TL 04-08 but may fit across 99-2010 Acura TL's and Honda (S2000) Replacement rotor rings: D008-05 Replacement brake pads: PD537 MSRP: $1,470.00 Now: $1,399.00 Add to Cart Compare Quick view RB 2pc Rotors (310x25) - Acura TL Type S w/Brembo Caliper FRONT 04-08 Weight comparison: OE: 17.5 lbs RB 2pc: 14 lbs Replacement brake pads:PD1001-391 Replacement rotor ring:D200-06 MSRP: $876.00 Now: $832.20 Choose Options Compare Quick view RB Brake Pad (ET800) for Honda Accord/S2000 00-08, Acura TSX 09+ REAR Thinner pads are made for rear RB kit 2145. MSRP: $120.00 Now: $114.00 Choose Options Compare Quick view RB Stock Size (300x28mm) Brake Kit For Acura TL/TSX/RSX/MDX Front Kit includes: 2 ea RB 4 pot calipers 2 ea Caliper adaptors 2 ea Light weight 2 Pc rotors 1 set brake pads (optional) You can order the complete brake kit or the rotors only (w/o calipers) as stock replacement (fits OE floating calipers) For the... MSRP: $2,211.00 Now: $2,100.45 Choose Options Compare Compare Selected × OK
