The brake system is designed and developed by RB with decades of experience in high performance brake systems to bring you the best value brake upgrade for your 2022+ Model X Plaid
This rotor kit is 410/390mm (wth 410/410mm option) vs. stock size 395/365mm.
The front big rotor has a wider annulus (76mm) to accomondate the larger (65mm depth) pad (see below) which can substantially increase the overall thermal capacity to lower the braking temperature - A foundamental, direct, and effective solution to overheating on the track (over changing the brake fluid, and installing a cooling kit etc.).
A real BBK that can help you handle your Plaid on the track with ease and confidence, so you can focus on improving your track skills and shortening your lap time. No more worrying about your brakes.
Front 410mm Kit fits 21" S Plaid OE wheels w/14.8mm clearance:
Rear 410mm Kit fits 21" OE wheels w/7.8mm clearance:
- 2 ea - Front oversized 2pc rotors
- 1 set - Front caliper spacer and hardware kit
- 2 ea - Rear oversized 2pc rotors
- 1 set - Rear caliper bracket and hardware kit
- 1 car set - Stainless steel braided brake line (optional)
- 1 car set - Brake pads
- 1 car set - Rotor retaining screws
- 4 ea - Pad Correction Pins
ROTOR WT. COMPARISON (LBS) | FRONT |
REAR 410x30/ 390x28 |
TOTAL/SIDE | TOTAL/CAR |
OE |
30 | 20.5 | 50.5 | 101 |
RB BBK* | 27.3 | 22/17.8 | 47.3/45.1 | 94.6/90.2 |
WT. SAVING | 2.7 | -1.5/2.7 | 3.2/5.4 | 6.4/10.8 |
Feature & Benefit:
- Kit comes with everything you need for a plug-and-play BBK.
- Retain stock calipers.
- Can use stock pads.
- Easy bolt on installation, fits under 20" wheels.
- Highly affordable.
- Oversizing your OE 1 pc heavy rotors to RB 2 pc light weight big rotors.
- Increase heat capacity while still saving un-sprung weight.
- Improve overall performance and look.
- 2ea (per caliper) pad guide pins are required to be swapped out for our correction pins (included).
- Requires to trim or remove front and rear dust shields to fit larger rotors.
- Front: D603-04
- Rear: D603-06 (390mm)
- Rear: D701-05 (410mm)
- Front large pad: PDTS2021_65
- Rear: PD1929
