Why Rears worn out before the fronts?
Take a look of the OE brake set up can help you better understand why OE rear is insufficient which doesn't get bigger along with the front rotor size (horsepower) over the versions:
Rotor size: Front/Rear (mm)
Brake caliper & pad: Front/Rear
We highly recommend rear BBK (390x30) for a more balanced brake for Trackhawk
