Quick view sku: PD1395B.PD8270 [PD1395B.PD8270] for McLaren 765LT, Senna - Front and Rear (See Description for Wear Sensor Location) MSRP: Now: $0.00 Choose Options Compare Quick view sku: MC-CRK-394.390 RB-CCB Replacement Rotors (394/390) for McLaren Senna/765LT Front & Rear (P/N 2R36 & 2R80) MSRP: $15,120.00 Now: $14,360.00 Choose Options Compare Quick view [PD1395B.PD8270] for McLaren 765LT, Senna - Front and Rear (See Description for Wear Sensor Location) Installation note: RB front pad wear sensor slot is on the side (vs OE in the center), you can either disable it or use extended connection. If you order other aftermarket (eg. Endless, Pagid) pads, we can only ship as they come, ie no sensor... MSRP: Now: $0.00 Choose Options Compare Quick view RB-CCB Replacement Rotors (394/390) for McLaren Senna/765LT Front & Rear (P/N 2R36 & 2R80) Kit Contents: 2 front CCB rotors (394X36mm vs. OE 390x36) 2 rear CCM rotors (390X34mm) 1 car set of ccb pads (optional) Features and benefits: Discs are made with continuous (long) carbon fibers for the strength & durability you want. Rotors are... MSRP: $15,120.00 Now: $14,360.00 Choose Options Compare Compare Selected × OK
