S2000
S2000
  • Product
  • Qty in Cart
  • Quantity
  • Price
  • Subtotal
  • On Sale
    OE Caliper Bracket for S2000 Rear BBK (+1" Upgrade)
    MSRP: $474.00
    Now: $427.79
    Was: $450.30
    This bracket will upgrade your S2000 rear OE rotors from 282mm to 307mm.Extended Bracket: Made of one-piece high strength ductile iron. Retain OE caliper support integrity (no adapter used like competition,
    CB15
    CB15
    MSRP: $474.00
    Now: $427.79
    Was: $450.30
    Qty in Cart: 0
    Quantity:
    Price:
    MSRP: $474.00
    Now: $427.79
    Was: $450.30
    Subtotal:
  • On Sale
    OE Caliper Bracket for S2000 Rear BBK (+2" Upgrade)
    MSRP: $474.00
    Now: $427.79
    Was: $450.30
    This bracket will upgrade your S2000 rear OE rotors from 282mm to 328mm.Extended Bracket: Made of one-piece high strength ductile iron. Retain OE caliper support integrity (no adapter used like competition,
    CB15A
    CB15A
    customfield1:
    CB15A
    MSRP: $474.00
    Now: $427.79
    Was: $450.30
    Qty in Cart: 0
    Quantity:
    Price:
    MSRP: $474.00
    Now: $427.79
    Was: $450.30
    Subtotal:
  • On Sale
    RB 2pc Rotors (300x28mm) for S2000 Front (Use Accord Calipers)
    MSRP: $789.00
    Now: $712.07
    Was: $749.55
    This 2pc rotor utilizes the same disc as Acura NSX with more thermal capacity (rotor and pad) than OE S2000 disc. However installation requires Accord calipers.
    2139
    MSRP: $789.00
    Now: $712.07
    Was: $749.55
    Qty in Cart: 0
    Quantity:
    Price:
    MSRP: $789.00
    Now: $712.07
    Was: $749.55
    Subtotal:
  • On Sale
    RB 2pc Rotors Heavy Duty (300x28mm vs. OE 300x25) for S2000 Front
    MSRP: $737.00
    Now: $665.14
    Was: $700.15
    This two-piece rotor is 3mm thicker than OE disc. It will still fit under OE caliper w/o any modifications but it will not work with any pads that are made thicker than OE pads (Known such as Carbotech). It mus
    2144
    MSRP: $737.00
    Now: $665.14
    Was: $700.15
    Qty in Cart: 0
    Quantity:
    Price:
    MSRP: $737.00
    Now: $665.14
    Was: $700.15
    Subtotal:
  • On Sale
    RB Caliper Kit (300x25) for Honda S2000 Front
    MSRP: $2,000.00
    Now: $1,805.00
    Was: $1,900.00
    Learn why RB Aluminum caliper kits are different from others. This kit includes: 2
    2081-K
    2081-K
    MSRP: $2,000.00
    Now: $1,805.00
    Was: $1,900.00
    Qty in Cart: 0
    Quantity:
    Price:
    MSRP: $2,000.00
    Now: $1,805.00
    Was: $1,900.00
    Subtotal:
  • On Sale
    RB OE Caliper BBK (307x12mm) for S2000 Rear (+1)
    MSRP: $1,463.00
    Now: $1,320.36
    Was: $1,389.85
    This Kit Includes: 2 ea. 307x12mm two-piece rotors 2 ea. Extended high strength brackets Repl
    2145-K
    2145-K
    MSRP: $1,463.00
    Now: $1,320.36
    Was: $1,389.85
    Qty in Cart: 0
    Quantity:
    Price:
    MSRP: $1,463.00
    Now: $1,320.36
    Was: $1,389.85
    Subtotal:
  • On Sale
    RB OE Caliper BBK (325x12mm) for S2000 Rear (+2)
    MSRP: $1,579.00
    Now: $1,425.05
    Was: $1,500.05
    This rear OE Caliper BBK will update your rear rotors from 282x12 to 325x12 but still is 0.5 pounds lighter than stock, yet will run at much lower temperatures to prevent brake fade, leading to faster lap time and lower replacemsnt costs on rotor and pad...
    2059K
    2059K
    MSRP: $1,579.00
    Now: $1,425.05
    Was: $1,500.05
    Qty in Cart: 0
    Quantity:
    Price:
    MSRP: $1,579.00
    Now: $1,425.05
    Was: $1,500.05
    Subtotal:
  • On Sale
    RB OE Caliper BBK (328x17) for S2000 Rear
    MSRP: $1,579.00
    Now: $1,425.05
    Was: $1,500.05
    2147
    MSRP: $1,579.00
    Now: $1,425.05
    Was: $1,500.05
    Qty in Cart: 0
    Price:
    MSRP: $1,579.00
    Now: $1,425.05
    Was: $1,500.05
    Subtotal:
  • On Sale
    RB OE Size (300mm dia) HD Kit (300x28 vs. OE 300x25) for S2000 Front
    MSRP: $2,221.00
    Now: $2,004.45
    Was: $2,109.95
    Kit includes everything you need for an easy bolt on installation. 2 RB 2-pc rotors 2 RB 4-Piston calipers (6061-T6 forged aluminum alloy) 2 Aluminum alloy caliper adapto
    2144-K
    2144-K
    MSRP: $2,221.00
    Now: $2,004.45
    Was: $2,109.95
    Qty in Cart: 0
    Quantity:
    Price:
    MSRP: $2,221.00
    Now: $2,004.45
    Was: $2,109.95
    Subtotal:
  • On Sale
    RB Replacement Rotor Ring 322x25mm (Incl. hardware)
    MSRP: $526.00
    Now: $474.72
    Was: $499.70
    Comes with the necessary hardware for each disc. Rotor Material: Racing Formula Alloyed Gray Iron & Heat treated Machining: Open SlotSurface: EDP Coating w/cross cut grinding on f
    D304-05-381
    D304-05-381
    MSRP: $526.00
    Now: $474.72
    Was: $499.70
    Qty in Cart: 0
    Quantity:
    Price:
    MSRP: $526.00
    Now: $474.72
    Was: $499.70
    Subtotal:
  • Choose Options
    RB Standard Duty BBK (322x25mm) for S2000 Front
    $1,800.00 - $1,899.76
    This kit includes: 2 Two-piece center-mount rotors 2 4-Piston calipers (6061 aluminum alloy) 2 Aluminum caliper adapters and hardware 1 Front set of RB performance street pads 1 Set Sta
    2015-K
    2015-K
    customfield2:
    322x25mm
    Qty in Cart: 0
    Price:
    Subtotal:
  • Total: items /
Adding your products to cart
