- 2 ea front CCM rotors (380x34mm) - Rotor has 67mm annulus made for Iron pad depth (62mm); not for ccb pad shape w/74mm depth.
- 2 ea rear CCM rotors (380x30mm)
- 1 set ccb brake pads (optional)
This CCM rotor kit is specially developed for 981 GT4 upgrading from Red calipers w/iron rotors direct replacement to the latest CCM brake technology.
- 100% Bolt-On installation, easier to install than replacing stock iron rotors due to lighter weight.
- RB discs are made with Gen 4 CCM technology; with long (continuous) carbon fibers and angle vanes.
- RB CCM rotors are stronger and can run cooler than OE pccb.
- CCM rotors (Brembo, ST or RB) have "Diamond hard" surface with excellent "Thermal Stability" so they will NEVER Wear*, Warp, or Crack (due to the heat). More advantageous for tracking/racing.
- Rotor annulus are wide enough to fit Pccb pads (74mm vs. iron's 62mm in depth) for lower braking temperature.
- Runs on street or tracks w/o temperature (cold or hot weather), or water (rain or car wash) effect.
- Never rust, always looks like new.
- Literally no brake dust.
- Reduce unsprung weight.
- Improve driving comfort.
- Inspiring braking confidence on tracks.
- Substantial reduction on maintenance cost and downtime in pad and rotor replacements.
- Save money than iron brake in the long run.
