    • RB 2pc Rotors (380/380) OE Caliper BBK for Porsche 996 GT2/GT3, 997.1 GT3/Cup; 997.2 Turbo , 992.1 CS Upgrade (P/N 2181-K & 2303-K)
  • Front rotor wt
  • Rear rotor wt
  • RB 2pc Rotors (380/380) OE Caliper BBK for Porsche 996 GT2/GT3, 997.1 GT3/Cup; 997.2 Turbo , 992.1 CS Upgrade (P/N 2181-K & 2303-K) RB 2pc Rotors (380/380) OE Caliper BBK for Porsche 996 GT2/GT3, 997.1 GT3/Cup; 997.2 Turbo , 992.1 CS Upgrade (P/N 2181-K & 2303-K) RB 2pc Rotors (380/380) OE Caliper BBK for Porsche 996 GT2/GT3, 997.1 GT3/Cup; 997.2 Turbo , 992.1 CS Upgrade (P/N 2181-K & 2303-K) Front rotor wt Rear rotor wt
    MSRP: $3,895.00
    Now: $3,700.00
    (You save $195.00 )
    POR-997-992-380 bbk
    This BBK is specially designed and packaged for upgrading your original 350/350mm to the same rotor sizes as 991/992 GT3 380/380mm.
    • Easy 100% bolt on installation.
    • No bleeding to your brake system - Save trouble in bleeding the system if you were to install a traditional upgraded BBK.
    • Retain OE calipers that you are familiar with for the same look and maintenance.
    • Lower maintenance/replacement cost
    • Increase you brake thermal capacity than original so they will last a lot longer.
    • Best value and the most affordable BBK for 996/997 & 992.1 CS2/CS4
    • Exclusively designed and built by RB.
    • Improve the overall performance and look with a BBK w/o the cost and hassle of an aftermarket or swapped BBK.
    • 2 ea front light weight 2 pc rotors (380x34mm vs. OE 350x34mm)
    • 2 ea rear light weight 2 pc rotors (380x28mm vs. OE 350x28mm)
    • 1 set caliper spacers & hardware kit
    • 1 set brake pads (optional)
    Replacement brake pads (for 996/997 calipers):
    • Front: PD991A
    • Rear: PD1300
    • Front: D501-04
    • Rear: D502-03
    • RB BBK (380/380) for Porsche 996 & 997 Upgrade (P/N 2338-K & 2433-K) RB BBK (380/380) for Porsche 996 & 997 Upgrade (P/N 2338-K & 2433-K)
      MSRP: $9,400.00
      Now: $8,930.00
    • Boots and Seals Kit - Porsche 997.1 GT3 & Turbo, 997.2 GT3, Cup, 997.2 GT3 w/PCCB Rear Caliper (Price is for 2 Calipers)
    • RB 2pc Rotors (380/380) OE Caliper BBK for Porsche 991 C2S/C4S Front & Rear (P/N: 2507-K & 2508-K) Front
      MSRP: $4,200.00
      Now: $3,990.00
    • Save 10% on Rebuild Kit for  Porsche 997.1 GT3 & Turbo, 997.2 GT3, Cup, 997.2 GT3 w/PCCB Rear Caliper (Price is for 2 Calipers) Save 10% on Rebuild Kit for  Porsche 997.1 GT3 & Turbo, 997.2 GT3, Cup, 997.2 GT3 w/PCCB Rear Caliper (Price is for 2 Calipers)
    • Piston Kit (Stainless Steel) - Porsche 997.1 GT3 & Turbo, 997.2 GT3, Cup, 997.2 GT3 w/PCCB Rear Caliper (Price is for 2 Calipers)
      MSRP: $280.00
      Now: $266.00
