Installation notes:
- Rotors are made for a direct bolt on installation w/o any modifications.
- Rotor thickness are adjusted, based on our experience, for an optimal & balanced performance between weight reduction and durability:
- Front reduced to 34mm (from OE's 36mm)
- Rear increased to 28mm (from OE's 26mm)
- 2 ea Front 2 pc rotors (395x34mm vs. OE 395x36mm)
- 2 ea Rear 2 pc rotors (396x28mm vs. OE 396x26mm)
- 1 car set brake pads (Optional)
Weight comparison:
ROTOR WT. (LBS) | FRONT | REAR | TOTAL/SIDE | TOTAL/CAR |
OE | 40 | 25 | 65 | 130 |
RB | 26.4 | 18.5 | 44.9 | 89.8 |
Wt Saving | 13.6 | 6.5 | 20.1 | 40.2 (31%) |
Replacement brake pads (By Porterfield):
Reference aftermarket vender:
https://www.velocityap.com/product/j...e-rotors-pair/
