These rotors are specifically designed and built for a direct replacement upgrade from OE's iron rotors, retaining G6 ZL1/1LE and CTS-V 6 pot front and 4 pot rear calipers (not included) for a direct bolt-on installation.
Kit Contens:
- 2 ea front CCB rotors (394x36mm)
- 2 ea rear CCB rotors (360x28mm) - 360mm fits better than OE 365 and can elliminate rusty lip like OE.
- 1 car set CCB brake pads
The kit is bundled with RB ST600 brake pads for street driving specially developed for carbon ceramic rotors ($1,000+ value), for other brake pads choose from options - Subject to availability.
ST600 characteristics is very comparable to Pagid RSC1 and OE Brembo.
- Consistent COF (Coefficient of Friction)
- Wider range of environmental temperature
- Excellent modulation
- Litterly no dust
- No squeak
- Highly durable
Replacement pads:
- Front: PD1395-360
- Rear: PD592M-360
ROTOR WT. COMPARISON (LBS) | FRONT | REAR | TOTAL |
OE | 27 | 23 | 50/SIDE |
RB | 14 | 11 | 25/SIDE |
WT. SAVING | 13 | 12 | 25/SIDE |
WT. SAVING | 50/CAR |
Calipers rebuild: Camaro
