Quick view sku: PD-ZR1-360 [PD-ZR1-360] RB Brake Pads for CCM Rotors - Corvette ZR1, Camaro Z28, Viper ACRE, Ferrari F458/California, Alfa Romeo, RB 6/4 Caliper Kit. FRONT & REAR: (PD1395 & PD1165) MSRP: $1,037.37 Now: $985.50 Choose Options Compare Quick view sku: PD1165-360 [PD1165-360] RB Brake Pads for CCM Rotors - Corvette ZR1, Camaro Z28, Ferrari F458, McLaren & RB4L Calipers REAR MSRP: $450.00 Now: $427.50 Add to Cart Compare Quick view sku: PD1395-360 [PD1395-360] RB Brake Pads (ST600) for CCM Rotors: Camaro Z28, ZL1 (G6), Corvette ZR1, Ferrari F458, Land Rover, Jeep Trackhawk, Ford GT/GT350, Viper ACRE, McLaren 570S, MP4-12C , Alfa Romeo Giulia & Stelvio Quadrifoglio & RB6L Calipers FRONT etc. MSRP: $704.00 Now: $668.80 Add to Cart Compare Quick view sku: PD1395.PD592M-360 [PD1395.PD592M-360] RB Pads Kit for CCM Rotors - Dodge Hellcat, Jeep Trackhawk, Camaro G6, Mustang GT350 Front & Rear Converting /Upgrading to CCB from Iron Rotors MSRP: $1,045.00 Now: $992.75 Choose Options Compare Quick view sku: GM-CRK-394.390 GM/Brembo CCB Brake Kit (394/390) for Camaro G6 2016+ & Cadillac V3 Upgrade (P/N 2C85 & 2C86) MSRP: $15,400.00 Now: $14,600.00 Choose Options Compare Quick view sku: H056-K RB Light Wt Rotor Hat for Camaro G5 Z28 Rear & G6 Upgrade to CCM Rotors (390x32mm) w/Z28 Calipers only - Not compatible with G6 Rear Calipers (2 ea. Incl. Hardware Set) MSRP: $1,936.00 Now: $1,839.20 Add to Cart Compare Quick view sku: H053-k RB Rotor Hat for Camaro G6 Front Converting to Z28/ZR1 CCM Rotors (394x36mm) - 2 ea. Incl. Hardware Kit MSRP: $1,560.00 Now: $1,482.00 Add to Cart Compare Quick view sku: GM-CRK-05 RB-CCB Rotor Kit (394/360) Camaro G6 2016+ & Cadillac V3 CCB Conversion Upgrade (P/N 2C85 & 2R12) MSRP: $12,815.00 Now: $12,174.25 Add to Cart Compare Quick view sku: RCCB-GM-03 RB-CCB System Kit (394/390) for Camaro G6 & Cadillac V3 (P/N 2C85-K & 2C86-K) MSRP: $16,800.00 Now: $15,960.00 Add to Cart Compare Quick view [PD-ZR1-360] RB Brake Pads for CCM Rotors - Corvette ZR1, Camaro Z28, Viper ACRE, Ferrari F458/California, Alfa Romeo, RB 6/4 Caliper Kit. FRONT & REAR: (PD1395 & PD1165) ST600 is a compound formulated for CCM rotors, good for street & spirited driving. Litterly no dust, no squeaking, excellent modulation. MSRP: $1,037.37 Now: $985.50 Choose Options Compare Quick view [PD1165-360] RB Brake Pads for CCM Rotors - Corvette ZR1, Camaro Z28, Ferrari F458, McLaren & RB4L Calipers REAR High metallic brake pads specially developed for Carbon Ceramic Rotors. Performance characteristics is comparable to Pagid RSC1 and OE Brembo. Consistent COF (Coefficient of Friction) Wider range of environmental temperature Excellent... MSRP: $450.00 Now: $427.50 Add to Cart Compare Quick view [PD1395-360] RB Brake Pads (ST600) for CCM Rotors: Camaro Z28, ZL1 (G6), Corvette ZR1, Ferrari F458, Land Rover, Jeep Trackhawk, Ford GT/GT350, Viper ACRE, McLaren 570S, MP4-12C , Alfa Romeo Giulia & Stelvio Quadrifoglio & RB6L Calipers FRONT etc. Installation Note: For Ford GT350 6 pot calipers installation it requires a hardware kit (included on request) to create proper tension from the hold down spring to the brake pads to avoid rattling. Brembo OE ZR1 brake pad dimension flow as seen on this... MSRP: $704.00 Now: $668.80 Add to Cart Compare Quick view [PD1395.PD592M-360] RB Pads Kit for CCM Rotors - Dodge Hellcat, Jeep Trackhawk, Camaro G6, Mustang GT350 Front & Rear Converting /Upgrading to CCB from Iron Rotors You save 10% when buying front and rear pads together vs. purchasing separately. MSRP: $1,045.00 Now: $992.75 Choose Options Compare Quick view GM/Brembo CCB Brake Kit (394/390) for Camaro G6 2016+ & Cadillac V3 Upgrade (P/N 2C85 & 2C86) This kit includes the following: 2 ea Front CCM rotors (394x36mm) 2 ea Rear CCM rotors (390x32mm) - Light wt RB hats option available 2 ea Rear 4 pot brand new calipers - Red color option available 1 set brake pads for CCB rotors 1 car set of stainless... MSRP: $15,400.00 Now: $14,600.00 Choose Options Compare Quick view RB Light Wt Rotor Hat for Camaro G5 Z28 Rear & G6 Upgrade to CCM Rotors (390x32mm) w/Z28 Calipers only - Not compatible with G6 Rear Calipers (2 ea. Incl. Hardware Set) OE Stainless Steel Hat:RB Composite Hat:CCM Rotor Assembled with OE Hat:<img MSRP: $1,936.00 Now: $1,839.20 Add to Cart Compare Quick view RB Rotor Hat for Camaro G6 Front Converting to Z28/ZR1 CCM Rotors (394x36mm) - 2 ea. Incl. Hardware Kit This hat kit (2 ea) includes all the hardware you need by switching the rotor hats from OE ZR1/Z28 front rotor assembly so you can have an instant upgrade to CCM rotors. Note: Discs are not included in the price, you must purchase from GM dealers or... MSRP: $1,560.00 Now: $1,482.00 Add to Cart Compare Quick view RB-CCB Rotor Kit (394/360) Camaro G6 2016+ & Cadillac V3 CCB Conversion Upgrade (P/N 2C85 & 2R12) These rotors are specifically designed and built for a direct replacement upgrade from OE's iron rotors, retaining G6 ZL1/1LE Calipers (6 pot front and 4 pot rear) which are not included in the price. The kit is bundled with our ST600 brake pads... MSRP: $12,815.00 Now: $12,174.25 Add to Cart Compare Quick view RB-CCB System Kit (394/390) for Camaro G6 & Cadillac V3 (P/N 2C85-K & 2C86-K) Kit contains: 2 ea. RB 6-piston caliper 2 ea. RB 4-piston caliper 2 ea. Front CCM rotor 2 ea. Rear CCM rotor 1 car set brake pads 1 car set brake lines MSRP: $16,800.00 Now: $15,960.00 Add to Cart Compare Compare Selected × OK
