Kit Includes:
- 2 ea front CCB rotors (400x36mm)
- 2 ea rear CCB rotors (360x26mm)
- 1 set CCB brake pads (Street pads included, track pads optional)
- Retrofitted front brake lines
- 2 ea front RB 6 pot calipers w/adaptors (Optional)
- 2 ea rear RB 4 pot calipers w/adaptors (Optional)
- 1 car set brake lines (If RB calipers are chosen)
Parking brake calipers are not included.
Front: PD1395B-360Rear: PD968-360
Feature & benefit:
- 100% Bolt-On installation, easier to install than replacing stock iron rotors due to lighter weight.
- RB discs are made with Gen 4 CCM technology; with long (continuous) carbon fibers and angle vanes.
- CCM rotors have "Diamond hard" surface with excellent "Thermal Stability" so they will NEVER Wear*, Warp, or Crack (due to the heat). More advantageous for tracking/racing with proper brake pads.
- Runs on street or tracks w/o temperature (cold or hot weather), or water (rain or car wash) effect.
- Never rust, always looks like new.
- Literally no brake dust.
- Dramatically reduction on unsprung weight.
- Improve driving comfort.
- Inspiring braking confidence on tracks.
- Substantial reduction on maintenance cost and downtime in pad and rotor replacements.
- Save money than iron brake in the long run.
Avoid:
- Running rotor continuously above threshold temp @650F
- Running brake pad below 1/3 of the lining material (~4mm)
