- 2 ea front ccb rotors (390x34mm same as OE)
- 2 ea rear ccb rotors (390x32mm vs. OE 360x32)
- 1 set ccb brake pads (optional)
- Rotors are made of continuours (long) carbon fibers so they are much stronger and more durable than OE.
- Rotors are designed and built for a bolt on installation - No modifications required.
- Rear rotors are oversized to 390x32mm BBK for a more balanced and moden performance and look.
- Retain your vehicle value but upgrading to better CCM rotors at the same time.
- Rear rotor hats are made fully compatible with OE drum parking/emergency brake.
