Quick view sku: PD1165-360 [PD1165-360] RB Brake Pads for CCM Rotors - Corvette ZR1, Camaro Z28, Ferrari F458, McLaren & RB4L Calipers REAR $450.00 $427.99 Add to Cart Compare
Quick view sku: PD1395-360 [PD1395-360] RB Brake Pads for CCM Rotors - Corvette ZR1, Camaro Z28, Ferrari F458, McLaren etc. FRONT $685.00 $650.99 Add to Cart Compare
Quick view sku: 2C16 RB-CCB (350x34) for Ferrari 430 Scuderia Rear $5,484.00 $5,300.00 Add to Cart Compare
Quick view sku: 2C15 RB-CCB (394x36) for Ferrari 430 Scuderia Front OE Replacement $5,789.00 $5,500.99 Add to Cart Compare
Quick view sku: 2C03 RB-CCB BBK (394x36) for Ferrari F430 (Non-Scud.) Front $7,701.00 $7,500.00 Add to Cart Compare
Quick view [PD1165-360] RB Brake Pads for CCM Rotors - Corvette ZR1, Camaro Z28, Ferrari F458, McLaren & RB4L Calipers REAR High metallic brake pads specially developed for Carbon Ceramic Rotors. Performance characteristics is comparable to Pagid RSC1 ($431) and OE Brembo. Consistent COF (Coefficient of Friction) Wider range of environmental temperature Excellent modulation... $450.00 $427.99 Add to Cart Compare
Quick view [PD1395-360] RB Brake Pads for CCM Rotors - Corvette ZR1, Camaro Z28, Ferrari F458, McLaren etc. FRONT High metallic brake pads specially developed for Carbon Ceramic Rotors. Performance characteristics is comparable to Pagid RSC1 ($729) and OE Brembo. Consistent COF (Coefficient of Friction) Wider range of environmental temperature Excellent modulation... $685.00 $650.99 Add to Cart Compare
Quick view RB-CCB (350x34) for Ferrari 430 Scuderia Rear Kit includes: 2 ea. CCM rotors (Replacing OE) Hat Design: RB rotor hats are made of forged (vs. billet) aluminum for better strength and rigidity. Lightweight $5,484.00 $5,300.00 Add to Cart Compare
Quick view RB-CCB (394x36) for Ferrari 430 Scuderia Front OE Replacement Kit includes: 2 ea. Front CCM rotors (394x36mm vs. OE 398x36*)* Diameter of OE rotor is 398mm but actual surface contact with brake pad is only 394mm, so 394mm disc will fit perfectly with stock calipers and pads. $5,789.00 $5,500.99 Add to Cart Compare
Quick view RB-CCB BBK (394x36) for Ferrari F430 (Non-Scud.) Front Kit includes: 2 ea RB 6-Piston heavy duty forged aluminum calipers. 2 ea Front CCM rotors. 2 ea Aluminum alloy caliper adapters. $7,701.00 $7,500.00 Add to Cart Compare
